Steels on an S2!
  • mcandmar
    • Apr 2004
    • 5118
    I found this parked behind me in Munich, very early example running on steelies with winter tyres. Had that purposeful look to it
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      Rather apropriate number plate then MAN!
      • dkw_dude
        • 555
        • Country: Norway
        #33
        Waking up an old thread! I have 996 tt calipers that scrapes slightly on 16" Avus which is used for winter tyres (205/55-16 Lappi studded). Will 16" steels provide some more space? From Transporter, Passat, Superb?
        Thanks in advance for input!
        Leif-Helge
        -91 S2 VEMS and Comp Turbo
        -12 B** 530XD Touring "S2 parts transporter, and daily driver"
          You can run 10-15mm front and 25-25mm (coupe) rear spacers on the OE wheels with 205 tyres, so just get those and an 80mm stud conversion.
          • dkw_dude
            • 555
            • Country: Norway
            #35
            Hi
            Brakes don't scrape against spokes but the inside of the "barrel". Sorry for not explaining clearly
            Leif-Helge
            • fish
              • Aug 2007
              • 2336
              #36
              Here, 9x16 dont say what ET they are though... Looks quite cool, but not a fan of the purple/white paint scheme. http://www.garaget.org/?car=60653
                Are you running 323mm discs?
                • dkw_dude
                  • 555
                  • Country: Norway
                  #38
                  Got the brake upgrade 2nd hand, they are bigger than 314 so 323 I think..
                  Leif-Helge
                    Unlikely to fit under 16s then I'm afraid. You could have the carriers machined and fit 314s. They definitely fit under 16s
                    • dkw_dude
                      • 555
                      • Country: Norway
                      #40
                      Hi, thanks for the replies!
                      I have been running them under the 16" Avus six spokes , with about zero clearance when I put them on. When I removed the wheels the calipers had grinding marks on them. Maybe from gravel getting stuck between wheel and caliper?
                      That's why I'm investigating whether steels have larger inside diameter than Avus alloys.
                      Leif-Helge
                      • dkw_dude
                        • 555
                        • Country: Norway
                        #41
                        Solved it by adding a 12mm spacer (inside of wheel is conical, moving it outwards created more space for the calipers). Wheel now rotates freely.
                        Measured the disc, it is 323mm also the caliper is spaced 5mm outward radially to have better clearance between brake disc and caliper.
                        Leif-Helge
