16 wheel for acq t85
  • BahoSSS
    • Aug 2007
    • 26
    • Country: Russian Federation
    I decided to install s2-suspension with 5*112 hubs.
    so, i have good BBS 8*16J discs from V8 - and want to ask - what type of SNOW(i'm from Moscow, we have e lot of snow) winter tyres will i install, that would normally fit with stock wings????
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    IMHO - you will bend, or break your BBS'es due to low profile (215(225)/40 R16) in bad visibility conditions, good winter tire (gislaved soft frost, nokian hakkapelita, etc.) will cost much $$, and still will be worse than good skinny R15 (205/50 R15).
    So if your brake fits, use strong "aero" R15 7.5J wheels from cars with UFO brakes and tire I've mentioned. It's my personal recommendation.
    Sau
    • Nj
      • Jan 2007
      • 3420
      • Home: Scotland Current: Finland
      Not many of us in britain see enough snow to make use of snow tyres so we probably won't be much help.
      Isveni
      Nj
      1990 CQ20v
      2001 3.0 B6 A4 Avant Quattro Sport
      • kwlw
        • Sep 2004
        • 1025
        Isveni
        You also don't expierence such nice things as sharp portholes filled with water (and you can easily break rim into), thick mud film on main streets mixed with salt - which tends to glue and make non transparent to any glass it finds... Especially windscreen and lamps . Wild pedestrians in winter masking suits (in non-reflective black) trying to get under wheels in unexpected parts of the road. Especially trained professionals, which are especially hard to notice and to avoid - those which ale called "babka".
        Of course you are blinded by the upcoming traffic lights and it is slippery... Oh how I "love" such winter. And don't recommend low profile european all year tire even for megapolis like Moscow.
        It much nicer when there's loads of snow, sunlight, -15 and you can get use from winter tire in such way:
        there was TRUE winter some time ago
        Sau
        • BahoSSS
          • Aug 2007
          • 26
          i've got a 215/55R16 tyres!!!
          if they do not fitt the wings - it meens the wings are bad)))
          sportquattro widebodykit will be installed)
          • kwlw
            • Sep 2004
            • 1025
            , that would be 5cm bigger diameter wheels than stock. If you will fit them somehow (maybe need some rubber rings into the springs, or roll out the arches), then it will be a proper jeep for streets of Moscow .
            Sau
            • BahoSSS
              • Aug 2007
              • 26
              well, no jeep!!
              and my springs are -25mm to stock.
              i desided to make 5*112 conversion in spring, and nowadays drive on ctock 14 wheels))
