How many turns for wheel bolts to be home?
  • curlyks2
    • 1069
    Question prompted by a garage telling me my wheel bolts aren't really long enough (they're not original)...
    How many turns do people need to get their wheel bolts fully home?
    Cheers,
    Ck.
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
  • Lee
    • 1512
    5 turns would be 7.5mm engagement. This should be about right and I wouldn't want to trust much less to ensure carrying the load on enough threads.
    Designun Limited....
    • curlyks2
      • 1069
      Thanks Lee.
      Follow on question... what's the maximum number of turns that can be accomodated without causing problems?
      Cheers,
      Ck.
      • S2Roo
        • 191
        Hi
        I'm not sure is there is a special case for wheel bolts, but I was always told that the length of thread engagement should be be no less than one and a half times the diameter of the thread itself.
        Roo
        • Stick Insect
          • Dec 2003
          • 2338
          Originally posted by S2Roo
          Hi
          Roo
          Roo once it's through the wheel hub having too much thread sticking out is no real advantage.
          The wheel hub is about 12mm thick (IIRC) i have one downstairs which I will check.
          The wheel bolts hold the wheel and the brake disk onto the hub.
          HTH
          David
          • Stick Insect
            • Dec 2003
            • 2338
            HTH
            David
            Just checked the hub flange is 12mm thick.
            David
            • curlyks2
              • 1069
              Is there any problem with having a couple of mm sticking through? I haven't gone looking behind there to know whether there's anything for the bolts to foul on if they do stick out a little behind the hub.
              Cheers,
              Ck.
              • Stick Insect
                • Dec 2003
                • 2338
                Cheers,
                Ck.
                I don't feel that this would cause a problem. It should be about 5mm I feel. I will look sometime to see how long it is before it fouls anything.
                David
                • Mikes2
                  • 1704
                  The standard bolts are 27mm long and cost pennies. Unless you have non standard alloys which prevent the use of the standard items it makes sense to invest in the correct bolts.
                  Mike
                  http://www.s2-audi.co.uk
                  • curlyks2
                    • 1069
                    I have kept all the standard bolts to go with the standard alloys for when they need to go back on to get me road legal again after shredding the tyres on the non-standard alloys at a track day...
