17x8.5 et20 wheels
    Originally posted by s2 on the way
    , true child labor.....he helped me with all of the million bolts to put them back together....
    one day I'll actually get around to giving her an actual paintjob, but for now, I really don't mind the primer either.
    Ahhhhh I've seen that pic in a thread on motorgeek, are you one and the same?
    • redz
      • 222
      Originally posted by anton
      if you do decide not to go with these wheels can you let me know as i've been after a set of these for about 2 years lol
      Ant
      Well i have two choices at the mo 2 piece or 3 piece spit.. so i'll let you know.
      I'm feeling the 2 peice as I've not seen any on a vag in the UK anyway.
      Andy
      s2 new project
      On going !!!
      • s2 on the way
        • Jul 2004
        • 220
        are you referring to the keskins that are 2 piece?
        yup, thats definitely me over there on motorgeek....
        • redz
          • 222
          Na defo OZ Futura.. only seen one set..
          Andy
          s2 new project
          On going !!!
          • s2 on the way
            • Jul 2004
            • 220
            #20
            good luck with them.
            mine are for a mercedes so the center bore is much bigger, but I got centric rings to take the stress off the lugs.
            not sure if the ones you are looking at are the same, but mine also have 15mm spacers bolted onto them that could be taken off to change the et from 20 to 35 (which I very well may do once I get some meats, 245's or so)....as for the fronts, the highest et I could manage would be about 27 or so to clear my brakes.
            if you don't go for them, hit me up in a bit because I might be selling mine. I'd do it now, but i'm about to get my car running again after rebuilding my head and need some rollers for the meantime.
