with the right et, a 9" should fit with no problems 7x17 et 15, so 9xXX et 40?
et 17x9" rim
I've got a 1993 audi 90 quattro i'm converting to close to s2 spec. I used A4 rear hubs which added 8-10mm to the overall width of the rear track. However any A4/s4 rear brakes are bolt on this car. 17x8 with 35 et and 225/45/17s fit well but were close to the fenders. I happen to sell the wheels to go buy a v8 engine for my coupe quattro project. However to get to the point I've got 17x8.5 ET 35 with 215/45/17s on the sedan now and that barely fits but it fits. So I would suspect 17x9s would work on a stock S2 but your tire size is very limited. I'd say 225 max. The problem with the S2 sedan/avant rear end if i remember correctly is that if the offset is higher it's too close to the rear upper control arm.
17x9s with somewhere from 25et to 35et would probably work but tire size is probably limited to 225 and 235ish if you roll the rear fenders.I chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
So those are mercedes SL 500 wheels. 17x8.5 ET with 215/45/17s.Attached FilesI chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
