19s
  • S2 Ant
    • 3682
    How much did you pay for the wheels and tyres?
    I ask as i have to get new tyres, but its only a bit more for totally new wheels as well, then i can sell my current wheels on making it even cheaper to do!!
    Ant
    2011 Kawasaki Z1000
    • Doug_RS2
      • 3847
      Originally posted by martinjs
      so who's bought dougs old wheels then???
      The forum boss
      • Doug_RS2
        • 3847
        Originally posted by Pisobiker
        Well Doug,
        ...... you now are ready to fit the gorgeous "RUF Porsche" carbon brakes with 14" rotors front and back
        Marco
        $28000 option
        If I was changing brakes, I would go with RS4 discs(360mm) and 6 POT AP Calipers - like on Lee's S2.
        • Doug_RS2
          • 3847
          £1170, free delivery from:
          Also:
          Rochford Tyres & Exhaust Ltd is a family run business and has been established since 1987. Serving the local community, public and local businesses alike.
          Alloy wheels UK from one of the leading alloy providers for all vehicles including new cars, classics, vans and motorhomes and more. Call 01244 813030
          • S2 Ant
            • 3682
            hmmmm 610 without tyres!!!
            Hmmmmmmmm now that is tempting as i know a few people that can get v good prices on tyres
            Out of interest, as ur car is lowered, did they go straight on or have you played around with the arches to make them fit??
            My car hasnt been lowered, so i guess wheels of this size should be a straight forward fit?
            Or would things scrub due to the suspension not being too stiff?
            Sooo many things to do, so little cash! LOL, thats the problem with all you old millionaires!!! us young'ens see all this inspiration but need to save for 20 yrs to afford it! LOL
            Ant
            2011 Kawasaki Z1000
            • Doug_RS2
              • 3847
              #21
              £599 at tyresave
              Mine is lowered - and yes the fronts are rubbing on the plastic liner under max braking/hard cornering, just inside the arch - Might have to remove it. I think you could get away with ET37, if not ET40 - I am thinking of getting 5mm machined off the wheels to bring them in a fraction as there is the room on the inside.
              On standard suspension it will probably still rub on max braking/ hard cornering.
              I'm only 27, and have a coupe, so enough of the old stuff :mad:
              • S2 Ant
                • 3682
                LOL @ Doug.
                Thanks for info mate
                Ant
                2011 Kawasaki Z1000
                • S2 Ant
                  • 3682
                  By the way Doug.... that pic of your 19's from the rear of the car makes an excellent wallpaper.... Thank you very much!
                  Ant
                  2011 Kawasaki Z1000
                  • Vagsport
                    • 533
                    19's may be a problem. I've got a set of 8.5" x 20" S8 alloys, with 255/35x20 tyres. Thes are going on my RS4 - engined 1990 Coupe q, but I am building the car AROUND these wheels, Sport quattro style, but with sheet metal.
                    • Doug_RS2
                      • 3847
                      #25
                      I did look at 20s but I could not find tyres narrower than 255 and I didn't want to do huge mods to get them to fit.
                      The problem going that big AND keeping standard suspension struts is that it is too big a diameter to fit under the spring bases. Also, the steering arm will mean it will have to stick out a lot.
                      Vagsport - you must be either changing the suspension struts and steering arm layout or getting big arches to get it to fit? Can't wait to see that.
                      • Vagsport
                        • 533
                        Yeah, I'm using custom coilovers, so the spring cups are a lot narrower than normal. We are modifying the bodywork, not just larger arches, but wider as well, more like the Sport quattro than an Ur quattro. This involves using sheet metal all round, after cutting the rear quarters away and building new wells for the wider / larger wheels.
                        • akojacko
                          • 107
                          #27
                          doug you need some of these to fit within thoses lovley alloys!!!
                          ako
                          • Doug_RS2
                            • 3847
                            #28
                            I would be interested to see how those compare to what I have fitted - 330mm AP Racing Kit - they just look very small now
                            Has anyone had experience of both?
                            • akojacko
                              • 107
                              #29
                              my wheels are only 18 s and these just fit in nice. 355mm.only thing that you need to be careful with is knowing wots behind you when you slam 'em on coz' summats bound to run up my *** one day...
                              ako
                              • Doug_RS2
                                • 3847
                                #30
                                I didn't realise they were 355mm - that's big. What brake pads to you use?
                                Do you have any problems with vibration? I have got into the habit of checking with a dial indicator everytime I take the wheels off just to make sure the discs runout is less than 0.003".
