9.5x18" ET30- How much arch work?
  • dog_day_sunrise
    • Mar 2008
    • 23
    As the title says, how much arch work will it take to get 9.5x18" ET30 Rota Torques under all four arches of a Coupé or S2? Bear in mind, also, that that includes an additional 20mm for hub adapters as the wheels are in 5x120 PCD.
    I guess another vitally important question is- will it even fit? Without the spacer taken into account the wheel offset calculator says that the inside edge will be nearly 25mm closer to the suspension strut.
    Just asking as a completely unused set has been offered to me for an idiotically low price.
  • Acidburn
    • 13459
    I've heard of 9jx19's being fitted but that was with mods to the suspension, you'd need the arches rolling, I currently have 19s on the s2 which catch slightly.
    btw is this coupe or avant (I know u mention coupe or s2 above but just checking)
    • dog_day_sunrise
      • Mar 2008
      • 23
      It would be on a coupé. I think clearance would be okay on the suspention as the offset is pretty high and they'd need a 20mm adapter.
      I've got a feeling that the arches might need to be extended with additional metal too, as you can only roll a relatively small distance and adapters included the wheels would be over 10" wide...
        Look at Wabtheking project thread he has 10" alloys on his car with arch work
