the wheels will fit but not with those tyres. you'll need 225-40-18.
also, you'll probably need 10 to 15 mm spacers also if the wheel offset (ET) is 45mm or larger.
You can *just* get 245 onto an 8J - I'm sure more than one lad has done it here and somebody did 255 IIRC - but yes spacers will be required for the A8/S8 Avus wheel onto S2 application.... Search for info on spacers here for that wheel - tis a popular option - looks lovely on the S2...
are you sure you'll get 245-45's on? i'm fairly sure they won't go. maybe 245- 30's,35's etc could be possible but not 45's. they hit the struts so the only way is to space them out a LOT and roll the arches right out. i think it could also be possible with coilovers buts that's quite an expensive solution for a coupe.
also, don't forget your rolling radius will be outside the +/- 2.5% "tolerance" so your speedo would be out anyway.
many people have bought 18's and they nearly always come with 245-45-18's on and the first job is to get them removed cos they don't fit. i've got 12 of them sitting in the garage with loads of tread!!
Just as I thought from reading other threads- The Avus 18's I've seen (£600.00 fitted with 245-45's) will fit the coupe with 15mm spacers & re-fit with 225-40-18's.... Yeah?
245/45 will not fit as they are a huge tyre. 225/40 are the norm, and i believe some are running 235/35. 15mm spacers also required to correct the offset.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
I was running 235/35/19's with spacers on the front (not lowered) and mine did rub every so often on the drivers side arch on hard cornering. Doug was running 255's on 19's lowered on his but that needed lots of work.
best thing to do is as mentioned above, get the correct tyres, then sell on the other one's
