What size tyre for an S8 18" rim on an Avant?
  • epic
    • 1317
  • Skull
    • 3506
    • Country: Slovenia
    Audi Quattro WR
      I'd be more 225/45 actually to keep original rolling radius but there is a little room for experimentation here... Could go 245/35 if you can play on perfect flat tarmac !
      • driftin jo
        • Sep 2007
        • 2222
        No you are wrong 225/45/18 does not keep the original rolling radius it is quite a bit bigger.
        225/40/18 is the size to go for even this is a tiny bit bigger than standard .
        standard size of 205/55/16 = circumference of 78.2 in / 811 revs per mile.
        225/40/18= circumference of 78.8 in / 804 revs per mile
        225/45/18= circumference of 81.6 in / 777 revs per mile
        For anyone who wants to play with tire sizes you will find this very helpfull.
        http://www.miata.net/garage/tirecalc.html
          Would 225/45 fit? maybe too big
          225/40 & 235/35 & 245/35 fit
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            im going to try 235/40/18. it is closer to the original on the rs2
            original being 245/45/17
              Fair does - cannot argue with them numbers...
              • madpugger
                • Sep 2007
                • 1901
                I have 235/40 on front and 225/40 on rear with 15mm spacer up front and 10 on rear. They are Eagle F1 Asymmetrics and 235s dont fit on the rear with a 10mm spacer, a 15 is needed. The Conti sports that were on the wheels when I got them were all 235s and fitted fine. The goodyear is obviously a slightly wider or squarer tyre.
                Le Mans 2012
                Nurburgring 700
                1995 S2 Avant
                • epic
                  • 1317
                  Thanks for all the info
                  • T2Andy
                    • 1903
                    I had 225\40\18 contis on my AVUS 18 10mm spacers ,perfect fit ,heavy ******s though
                    • Bram
                      • Aug 2006
                      • 2582
                      I currently have 225/40 on my S8 Avus rims and 15mm spacers, but next time I will get 235/40 as these tires are a bit wider that would make it look better and fit better as well. 225 is really the minimum width you can fit on the rims.
