Evening all,
I've been an S2 owner for 3 years now and have never really documented anything so here goes.
I currently have standard 16" Avus on my S2 which in my own modest way are immaculate. I've always taken care of them and have always helped the car to look good.
However, I have always wanted 18" wheel as I think the S2 is horribly "under wheeled". My goal since day one was always a set of 18" S8 Avus' (1 generation) but the fact that these seem so rare and so expensive (understandably) I have decided to go with option 2 and a set of Audi A8 sport wheels.
I won two wheels initially on eBay for a bargain price. One wheel is perfect, the other needs a bit of work. Then Steve (Knight Rider S4) has sorted me out with a second pair which hopefully will be arriving shortly (thank you very much Steve).
Firstly, a comparison of old and new (note the 245/45's have since been removed)
Second picture was a trial fit (although not a successful one due to the obvious offset issues).
I'm going to start the leg work myself and then get all 4 refurbished properly so they all match. This is annoying because one of them is perfectly ok but I want them to look right.
I haven't decided on who to refurb them but if anyone has good reports of somewhere in the Midlands that can do them the I'm all ears.
I will get them painted in Audi paint code Z17 (standard silver) as my car is Volcano Black. Not sure whether powder coating or just regular paint is the way to go. Again your thoughts are welcomed on this one.
I will go for 20mm spacers both front and rear (hubcentric) although I wouldn't mind hearing people's opinions on this as I was thinking slightly more on the rear to get an "RS2 track". I'm not sure whether to get spacers that bolt to the hub or spacers that require longer bolts.
I will go with the tried and tested route of 225/40/R18's tyre wise and will try Toyo Proxes as I have these on my A4 with good results.
Ultimately the 3rd photo is my goal (apologies for the using this image if it's your car)
And after all that I know that my ride height is gonna be horrible and thus project 2 commences.
This will probably take some time but I'll try and keep it updated and show progress as I try and do a lot of the work myself (including designing some spacers).
Thanks for reading
Dan
Thanks for reading
Dan
