Mini Project: A8 Wheel Upgrade
  • merlin's S4
    • Jan 2005
    • 1539
    Originally posted by Le S2 Audi
    I used 15mm spacer's & fitted 235-45-zr18 - which by the way is the nearest size to keep the speedo reading correct (or within the 3% recommended by tyre fitters) when changing from the standard 16" Avus 225 tyres...
    235 45 18 is way too big. Nearly 6% bigger than standard. With a 40 profile you'd be ok as the difference is under 2.5%. 225 40 18 is less than 1% out and is by far the cheapest tyre option.
    See here...
    Free tyre size calculator and comparison tool. Compare two tyre sizes side by side or find alternative sizes within safe rolling circumference tolerance. See diameter, sidewall, circumference, speedometer difference and visual diagrams.
    • Le S2 Audi
      • Jul 2009
      • 3805
      See here...
      http://www.alloywheels.com/tyrecalc.asp
      Sorry I got it wrong they are 235-40-18's fitted!!
      But My car orginally had 225-55-16's fitted and using the above calc thingy and asking at my tyre dealers the 235-40-18's come's in under the 3% differance....
      New S2 - S8 & RS2 -RS6 Keyrings
      • Dpicariello
        • Mar 2006
        • 621
        Got a good quote from Redditch Shotbalsters. They can powder coat too. I think I'll go for that.
        This is my first "prepped wheel" I didn't take a picture of it when I got it but it was a bit ropey.
          Powder coat is a far better wheel coating than paint Dan - its just much more expensive and thats why most refinishers just use paint
          • Dpicariello
            • Mar 2006
            • 621
            I've managed to spend a few hours on these wheels recently. All wheels have been shotblasted and I've filled and sanded any dings kerbing etc. Just about to take them to be powder coated silver. I asked the powder coaters if the filler would be ok during the process and they said they'd have to see.
            Just wondered if anyone had any experience with powder coating over filler.
            Looking forward to getting these on the car after seeing some more examples on ehre recently.
            • Fat Audi 80
              • 10547
              As long as it is smooth the finish should be fine. Don't forget that they will be baked during the powder coating process so the filler needs to be able to withstand that level of heat. (I can't remember the temp off hand. 200 deg C ish I think).
              Cheers,
              Steve.
              The Perfectionist
              • Dpicariello
                • Mar 2006
                • 621
                Ok so for reference you can't really powder coat over filler. I should have guessed really and I'm surprised the powder coaters hadn't come accross this before.
                The powder is electro-statically attached to the wheel (or metallic object) and hence the reason why it won't cling to the filler. Very thin areas of filler may reep better results, I don't know.
                I'm picking the wheels up tomorrow morning and taking them to Lepsons for a quote. If all is good then I'll leave them there for a full and thorough re-furb.
                This is taking far too long!
                  yup, thats why you should really get any real kerb rash ally welded then grinded back before PCing
                  • Dpicariello
                    • Mar 2006
                    • 621
                    I'm a happy man..........
                    Just picked up the wheels from a chap down the road who has done himself proud.
                    They are perfect, sprayed in Avus Silver and lacquered beautifully so that the colour looks fantastic. Really deep shine without any polish. I can tell there's a few hours gone into these even after my hours in the garage sanding and smoothing.
                    I'm nearly there!
                    • merlin's S4
                      • Jan 2005
                      • 1539
                      They look great Dan! Now get the spacers made, buy some tyres and get them on the S2!!
                      • Fat Audi 80
                        • 10547
                        They look nice!
                        The Perfectionist
                          Thems looks lursch me babber
                          • Dpicariello
                            • Mar 2006
                            • 621
                            Right,
                            Time to breath some life into this thread again.
                            Since getting the wheels refurbed my wheel project seemed to hit a brick wall. The combination of an expensive Christmas holiday coupled with two mortgages has made S2 ownership tough, let alone S2 modification.
                            Anyway, the wheels are now wrapped in Toyo Proxes (TR-1's) and are awaiting fitment. I have extended bolts but the stumbling block is my spacers. I have had a machine shop make me some but it's taken a bit longer that I thought but hopefully I'll have them very soon.
                            Anyway, a few pics to update and a very dodgy, mock up so see how they'll look. I cannot wait for this. The fact that it's taken so long and I have put so much elbow grease and effort in getting them to look like this means that the end result will be so much sweeter. Hope you'll all agree.
                            • Fat Audi 80
                              • 10547
                              They are going to look sweet Dan!
                              Now get them bloody fitted!
                              Cheers,
                              Steve.
                              The Perfectionist
                              • Dpicariello
                                • Mar 2006
                                • 621
                                Progress!!!!
                                Today has been a good day. Picked up my spacers as designed by me yesterday and if I do say so myself they fit beautifully
                                So here are the fruits of my labour.
                                I've gone for 20mm spacers front and rear which has resulted in a dream offset (ET 28). The wheels sit really nice, particularly the fronts.
                                Yes, I know the car needs lowering now, I knew this all along and as soon as I can address the issue I will but I tend to take my time over these things!
                                I've got Toyo Proxes TR-1's all round and each wheel has now been treated to Chemical Guys wheel guard plus some Meguiars dyre dressing
                                Comments welcome (please be nice, there's so much blood sweat and tears gone into these)
