urS6 track wheels
  • urS6Tom
    • 773
    urS6 track wheels
    i want to buy some wheels for my urS6 to use on the track, but have no idea where to start. i've currently got the S6+ 17" on there and i like them, but they're pretty heavy.
    so, my requirements are:
    biggest wheel and lowest profile tyre that will fit in the arch
    as light as possible
    easy to fit
    look good in black
    not ridiculously expensive (in fact i'd prefer to buy them 2nd hand)
    any suggestions appreciated!
    cheers,
    Tom
  • trackslag
    Account Disabled
    • Sep 2009
    • 171
    doyou mean black wheels or on black car, there are the cream of race wheelsnot very one cup of tea but im going togofor some thing llike these on mine for track use.
    Browse our range of alloy wheels and order from Compomotive Wheels online today.
      compos are nice - and light too more importantly - OZ is ultimate though more wonga !
      • urS6Tom
        • 773
        i like the look of the compomotives actually!
        is it best to keep front and back the same width, or could you go 8x18 on the front and 10x18 on the rear? not sure if 10x18 would fit in the arch actually....
        think these in black would look good too
        http://cgi.ebay.co.uk/Compomotive-MO...QQcmdZViewItem
        • urS6Tom
          • 773
          ok, here's an offset question - haven't quite got my head around this yet
          Stock wheels on the S6 were 16x7.5 with ET37
          I'm now running the S6 plus wheel which is 17x8 with ET40
          I think I've settled on the Team Dynamics ProRace 1.2 in an 18x8.
          In the correct stud pattern (5x112) they come in ET35 and ET45
          My questions are - which ET is better for my car, will I need spacers for them and does it matter what tyre size i'm going to use (thinking of 255/35 R18 Toyo 888)
          Cheers,
          Tom
          • martinjs
            • 3205
            Tom, im presuming you have 255's on your S6+ wheels? (they usually are)
            If thats the case you need to decide if there is allowance for your wheel to sit 5mm further out to run ET35 on those new wheels and not look out of place or foul on anything. 255's on those S6+ wheels do fill the arches pretty well already.
            Nice wheels btw.
            Similar to my compomotives, ET30 also 8x18 but my tyres are 225's.
            • urS6Tom
              • 773
              Nice wheels btw.
              Hi Martin - I actually put 235s on the S6 plus wheels as 255s were a bit tight and had heard 235s gave a better ride.
              Love the look of those compomotives! which wheel are they? did you need spacers?
              What car have you got btw? Any more photos?
              • martinjs
                • 3205
                They are MVS, no spacers. I have a UrS4.
                I dont have any more pics to hand, they are off the car for the moment, might go back on after winter, not sure yet.
                • urS6Tom
                  • 773
                  So are those tyres 225/40/18?
                  What springs are you using on the back?
                  • merlin's S4
                    • Jan 2005
                    • 1539
                    Cheers,
                    Tom
                    ET35 no question.
                    • urS6Tom
                      • 773
                      Thanks for the advice.
                      My tyre option (probably going with Toyo R888) is 225/40/18 or 255/35/18.
                      I'm assuming the wider, lower profile tyre would be better for the track. Is that right?
                      • merlin's S4
                        • Jan 2005
                        • 1539
                        Yes go for the wider tyre as long as you have clearance. I ran 255s without issue but I had wheels with an ET30 offset at the time. The wider tyre will really help cure the notorious understeer too.
                        • martinjs
                          • 3205
                          Yes, im using h&r springs.
                          • kingfishers2
                            • Feb 2007
                            • 756
                            Not an s6 but Ill be using these very light and reasonably priced, DARE DRIFT RG2
                            • urS6Tom
                              • 773
                              Given that the S6 plus wheel is ET40 and supplied with 255s, shouldn't ET35 and 255s definitely be OK? Or have I got my offsets confused
