Tyres
  • rotoryboy
    • May 2004
    • 3281
    Tyres
    Hi Guys. Is it right that if you change tyres on the S2, you should change in four's? or doesn't it matter? Basically I've got 3 x tyres with about 4-5mm on and one was replaced before I got it with a crap Fulda thing . I'm trying to work out if I can put 2 x new one's on the front and the good one I take off can go on the spare. Will she run right with 2 x brand new and 2 x worn tyres?
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    You should change in pairs mate so that you dont get uneven load on the differentials.
    Put the newest tyres on the front and worn on the rear.
    • s2carlo
      • 252
      Replace in sets of two is no problem.
      However make sure that the basic tyre set is the same size!
      Different sizes (205/60 for one pair and 205/40 for the other) will damage the diffs. You will hear it directly however.
      If it's not correct there is a terrible noice and vibration in the car when turning or powering up if it's NOK.
      BTDT
      No power, no glory!
      S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
      • Graham
        • 1622
        Correct me if i am wrong but as long as the tyres have the same rolling circumfrence there should be no problem. The main worry is if you have larger on the front or larger on the rear there is an imbalance between what RPM the front have to do and what the rears have to do. e.g. if you have 205x55 16's on the front and 205x45 16's on the rear, for every one rev the fronts have to do, the rears have to do 1 and a bit revs to cover the same distance. If it is like this your asking the central torsen to compensate for this difference, and at speed that will kill the torsen. It is bad practice to have two different makes of tyre on the same axle as the tyres could have completely different handling characteristics, and one might weigh more than the other so you get more rotating mass on one wheel than the other and then you have too worry about brakes and the likes. But as long as the tyres on the front are both the same and the same size as the rears there should be no problem.
        HTH
        Graham
        • Graham
          • 1622
          Damn beat me to it LOL
          Graham
          • rotoryboy
            • May 2004
            • 3281
            Sound's good to me . Two new tyres for the front then. Cheers chaps.
            Mark
            Race Clio RS197
            • A6 AVANT
              • Nov 2003
              • 321
              Don't know where you getting your tyres from but I just bought 2 x Michelin pilot primacy 205/55 R16's "H" rated from www.mytyres.co.uk for £68.90 each!! delivered from Hannover!
              HTH
              Chris
              A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
                • 12431
                Also worth giving my dad a call on 01939 262020 he can do pretty good prices on tyres also.
                • Stick Insect
                  • Dec 2003
                  • 2338
                  Just a quick point about tyres 205/50 x 16. My Mondeo 4X4 is very reactive to front tyres
                  here are some findings.
                  Michelin Pilot Sports brilliant in the dry, terrible understeer in the wet.
                  Goodyear F1 amazing in the dry and brilliant in the wet.
                  Yokohama Advan A8 excellent in the dry and pronounced understeer in the wet.
                  I have some Michelin Pilot HX tyres on the rear and I'm getting bored of them. they must be 28K old. They seem rock hard.
                  HTH
                  David
                  • jameswkr
                    • 538
                    How are the ZR rated ones on your Morris Minor ?
                    • rotoryboy
                      • May 2004
                      • 3281
                      Any opinion on TOYO PROXIS?
                      Mark
                      Race Clio RS197
                      • s2driveruk
                        • 12696
                        yep had a set of those Michelin HX on my Coupe a couple of years back, front ans rears lasted a lifetime, infact got the rears in the garage still, I think after 30 odd K miles there was still a good 3mm of tread on them. Very hard sidewall but a bit lifeless - good for motorways if thats what you do 90% of the time (as i was)
                        Cheers,
                        David
                        1992 3b S2 Coupe
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          Strange you should mention it James I have a set of Yokohama A-001? ZR tyres from a friends racing car 185/50/14 on 5.5J rims for my latest project. I have not driven on them yet, but I will report. They were a previous season control tyre. ( and they were Free)
                          Normally i use 155/80 14 at £22 each I can break the back end away at 18MPH on a wet roundabout.
                          David
                          • Dr H
                            • 1175
                            I've got em and they're great! I used to have Continentals and the extra grip the Toyos give is amazing in comparison. MAde the other feel like bars of soap
                            Mytyres.net don't seem to have them at the moment but when they do they are very cheap for the standard size.
                            You might want to contact this guy selling in ebay - he may have Proxies in the standard size (he is listing lots of other sizes at the moment).
                            http://stores.ebay.co.uk/LEIGH-TYRES...enameZl2QQtZkm
                            • 20vTurbo
                              • May 2004
                              • 233
                              • Home: England Current: Australia
                              Best tyres I've had on the S2 are Bridgestone S02's (which they don't make any more) - I've now got S03's which are just as good. Good in both wet and dry conditions. The only other tyre I've tried on the S2 is Yoko A539's - they were nowhere near as good as the Bridgestones, so I won't be buying any more! They were OK when fitted to the Golf I had, but they can't cope with the extra power of the S2.
                              '94 S2 (RS2+ spec. Tarmac Rally Car)
                              S2QuattroMotorsport
