Nokian Wr G2's on Avus 16's for winter instead of the Avus 18's. They've been superb, too much grip for fun! In 215/55 for the mothership sized A6...
Winter Tyres
1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
1987 CQ85RS
1994 S2 Avant- Gone
1991 V8 -Gone, but lives on in the TDi and CQ
Fintray Hillclimb - 33.20s
Doune Hillclimb - 55.02s
Forrestburn Hillclimb - 52.61 -
'H' rating for the oil burner...
1987 CQ85RS
1994 S2 Avant- Gone
Forrestburn Hillclimb - 52.61Comment
It's prob at least a V speed rating as that is 149 mph, H is only 130 so they wouln't have fitted them on the S2 from factory from new.
I always go as high as i can get usually Y whitch is 186 mph, my Vredestein's are a W whitch is 168 mph , that is very high speed for a winter tire . A lot of winters are only up to 130/150 mph H/V .
I just had a look and i can't find a winter tire in a 205/55/16 that is higher than a V rating 150 mph.Comment
you could give these a try if your on a budget ,http://cgi.ebay.co.uk/205-55-16-91H-...item563857b0e0
they are H so only rated to 130 mph but if you are going to change them over after winter I don't suppose that's a problem.Comment
Pirelli Snowsport are a great winter tyre for the S2... comes in the right size and H rated too. Work lovely in cold weather as I found at last year - being able to gently overtake just about anything in the snow.Paul Nugent
Yup, have the Nokian WR's on my A6 and they are stunning in the wet and on snow/ice. Same upgrade route too from a snowsport 210 Pirelli and the delta is pretty significant.
Andy if buying 2nd hand, dont buy with less than 5mm depth. below this they are considered as getting towards the end of their service life and check on date as th rubber is a different compound and hardens over time. 3-4years old and they will be pretty much on their way to end of life too in theory.sigpic
1992 3b S2 CoupeComment
I'm looking to get the clio out of the drive instead of using the S2, as its a bit of a risk and setup for track really.
As standard its got 15" alloys with 185/55 toyo T1R's on it, and it isnt going anywhere.
I've been looking at Vredestein Snowtrac 3's, Nokian WR G2's and Falken HS-439's which all seem pretty good.
I figure i can fit 175/65/14" winter wheels and all should be ok? I can't find any steel rims, so another set of alloys it is.S2Forum.com AdministratorComment
I have the proper winter D90 wheels and tyres for the RS2. I used them when we skiing and other than looking bloody aweful they worked very well. Some sort of Dunlops.
However sod getting the RS2 covered in salt and avoiding S2 folk crashing. Its tucked up for the winter!
Using the pub bus as daily with 195 70 14 fulda KRISTALL MONTERO on and they are just amazing! will get you up what our A4 avant tdi quattro will and better at stopping!
Mytyres were best price.Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
