Tyre Sizes
  • Sidspud
    • 1223
    Tyre Sizes
    Can someone explain tyre sizes to me. I currently have 235-40ZR18. I know what all these numbers mean (235mm wide - 40% of 235mm tyre wall depth - Z speed rating - R18 for 18" wheels), but how can I work out what other sizes will fit on my wheels?
    I have been told that 235-40 is an unusual size and therefore tyres might be expensive and that I should go for a more standard size, but I don't know what a "standard size" is.
    Can someone help?
    ex '93 Avant owner
  • sal_s2
    • 1291
    I have 225/40/18 on mine which are slightly slimmer so the side wall is slightly smaller as well.
    • mcandmar
      • Apr 2004
      • 5118
      Yep mine are 225/40/18 too, I believe 225 is correct, having said that it depends on the width of your rim. Don’t ask me what mine is as I don’t know, but the tyre is exactly the same width as the rim, i.e. damn easy to grind of curbs.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • peterp
        • Oct 2003
        • 49
        If you calculate the diameter of the 225/40 - 18 you will see it is a better match with the standard 205/55-16 (235/40 being 8mm more in diameter than the 225/40, being already slightly bigger than standard)
        For the moment 225/40-18 is a "normal" size. Newer cars will rather be 235/40-18.
        Peter
        • Martynf
          • 1885
          Kenny,
          use this mate: http://www.tyresave.co.uk/tyresize.html
          very useful !!
          225/40/18 is what they are saying to be the 'common' cheaper tyre. 235 is big for an avant!! I remember Lee saying some tyres are wider than others even though they are the same 225's!!
          Martyn
          www.vagparts.com
