BBS LM's and spacers required?
s2bug's Avant that's for sale at the moment has extended arches:
This is so that ET20 RS4 wheels will fit.
Rolling the arches would be less extreme than this but gives you an idea. The trouble I've heard with rolling the arches is that the paint can crack.Comment
Only if the guy doesn't know what he's doing! it's so common place, ask Quattronutter to do it or your local go faster place.s2bug's Avant that's for sale at the moment has extended arches:
8.5's
if your trying to run 18 x 8.5's everything has to line up absolutely perfect. as jamo says et30 to et35 will make the difference. with et35 your 5mm further in but you would have the option to spacer out a couple of mm if necessary, with et30 your already fixed 5mm further out (that's on top of the extra wheel width!!)
its so critical you'll find that even if you do get the wheel lined up some makes of tyres will rub and others won't even when they're supposed to be the same size.
