Avant spacers for front to make same as rear?
  • dest
    • 4287
    As title
    What is the best size spacers to fit on the front to make the wheels sit the same as on the rear? Im guessing 10mm is nearest
  • Gompa
    • Oct 2008
    • 285
    I run 20mm spacer on back and 25mm on front I'm running 8x17 et 45 or 48 something silly high standard, why Audi always make them such high offset all the time
    • dest
      • 4287
      So I guess your fronts still sit narrower than the rear then?
      I currently have 5mm spacers on the front and its not enough
      • Gompa
        • Oct 2008
        • 285
        Yer by a good way I would go 10 as my fronts sit just inside of arch where as the rear sit just dead level, I'm trying to get 18's as I want to lower mine a bit more but it will bottom out everywhere on 17's
        • dest
          • 4287
          Mine is on H&R springs with 18's, it only ever bottoms out on big speed bumps on the cats, but that is quite rare.
          • Gompa
            • Oct 2008
            • 285
            that's good to know mine ison the H&R's as well but would like coilovers as i want 45mm drop and the damping on mine is past it's best as it crashes about a bit
