RS2 spacers
    RS2 spacers
    Has anyone ever purchased RS2 wheel spacers or know of a company that makes them?
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    Never thougt about it but....
    I guess any good and known company that deals with Porsche will have them.
    Got this with google.... any goood?
    http://www.audisportclub.com/
    http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
    • Puglife
      • Jun 2006
      • 731
      Does Bambridge not do them? If not i'm sure he could knock something out
      Jay - pug_life85@hotmail.com
      1986 Audi UR quattro - WORK IN PROGRESS
      1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
        http://www.porscheshop.co.uk/acatalo...r_porsche.html
        Porsche ones are no good, Porsche has a 71.5mm centre bore and the RS2 has 73.1mm
          1st person I sent a PM too yesterday Looking just incase he can't
          • veneto rs2
            • Jun 2006
            • 1022
            • Country: Veneto
            Yes you're right Jamo but.....
            To skim down 1.6mm from the centre bore would not be such a big deal, eventually the other five holes are the important ones.
            I've done already the skimming on a 964 wheel that I found for a very good price and it took twenty secs with the right machinery (an enourmous lathe made in England)
            Personally speaking I believe it's easyer to get that job done on a Porsche spacer (plenty everywhere) then find a company that makes a spacer 5X130 with a 73.1mm centre bore..... any normal size lathe and few minutes will do.....
            Stefano
              The RS2 centre bore is bigger than the Porsche so you cant skim down 1.6mm you would need to make it 1.6mm bigger!
              • goodall
                • Jul 2008
                • 810
                Widen out the spacer and use a spigot ring on the wheel, however might be handy just get right ones made
                thought you had S8 alloys and S2 hubs jamo....
                • jorge s2
                  • Feb 2009
                  • 226
                  • Home: Portugal Current: Spain
                  i thing momo do them at least i saw them once in a tunning shop in spain.
                  audi s2 aby red 1993 powreded by prj
                  • Acidburn
                    • 13459
                    If you can get the spacer you want then I can enlarge them as aidens same as I did a exhaust sealent ring for him for the black golf under the covers there. Should not take to long to do as well, just as long as the spacers the size you want and stud pattern enlarging the center bore is not too bad.
                      spigot ring, good shout, have to investigate that
                      However still have a problem. For those of you without RS2's the centre bore is not like an S2, it is 3 prongs like the porsche hubs
                      In all the porsche spacers I've seen these locate inside the spacers in 3 other prongs
                      Because the Rs2 is a bigger bore it will not fit inside this style of spacer
                      • PaulJ
                        • Jun 2008
                        • 253
                        Spacers
                        I,ve done it the long way, removed hubs and machined down centre in a lathe to 71.4mm giving 0.2mm clearance, allows me to fit any porsche wheel, machined ally rings to sit inside the standard wheels although this does not seem to bother the wheels too much as the studs are in the hubs, HR do spacers which are very good but again porsche sizes, I'm assuming the wheels are porsche spec with the smaller centre bore, Its a pain to do, even more so at the rear with the handbrake and all so I'm going to do the poly bushes at the same time and perhape the ally subframe bushes as well as new wheel bearings
                        Cheers PJ
                        1995 RS2 Nogaro
                        1971 Lotus Elan Sprint
                        1974 Lotus Elan+2S 130/5
                          Bambridge has confirmed he can make some so I'm going nowhere else! thanks for the replies
                          • veneto rs2
                            • Jun 2006
                            • 1022
                            • Country: Veneto
                            Just for future reference....
                            I was at dinner with Tom Saltinot in ingolstadt last sunday and he (correctly) say that hubs from Porsche 944/968 have the centre bore in the size of 73.1 mm.
                            Hence spacers for these Porsche models will fit RS2s without mods/machining.
                            Stefano
                              Stefano
                              Unfortunately they are mostly sold as non hubcentric spacers hence why I discounted them
