Looking for a new set of wheels for my car and found a deal but I'm not sure if ET45 is ok... I think I would need maybe 10mm spacers to clear the brakes but will the wheels stick out the fender ??
How about rubbing issue ? Anyone experience driving with these kind of wheels?
Not sure what car ur putting these on but........35mm is the semi normal. The Avant s2 sits alot further in tho. Front of mine, ET35 needed 20mm spacers to bring it out. Bigger the ET the further in the wheel will sit ie ET 45 will sit in 25mm more than ET20.
ET45 means it's closer to the inner tie rod rather than the "fender" depends on the wheel some have run the A8/A6 wheel with ET45 with no issues with 8J
The only complication I see is they are 8.5J so they are very wide rims, you may end up having to have 15mm spacers to clear tie rods and have the arch rolled as typically 8.5J Coupe alloys run ET 30-35 to clear.
I would say 10mm spacers you should be fine then. It's not an exact science I know one set of 18x8.5 alloys that didn't rub on one Coupe and were sold to another member and he had to have the arches rolled, go figure
