Type 85 CQ Spacers.
  • Ian Simmonds
    • Jun 2005
    • 2858
    Type 85 CQ Spacers.
    What is the type of wheel bolt for a type 85CQ? and is it in this list by chance? These are the options listed.
    3/8" UNF studs to suit (old) Minis etc: 10mm, 19mm or 25mm wide spacers
    7/16" UNF studs for Ford Escort, Cortina Mk1/2 etc: 10mm, 19mm, 25mm wide spacers
    12 x 1.5mm studs for Ford Escort Mk2 on, Cortina, Capri etc: 10mm, 19mm, 25mm wide spacers
    12 x 1.5mm studs for Vauxhall/Opel: 10mm, 19mm, 25mm wide spacers
    12 x 1.5mm bolts (60 degree taper seat) for BMW, Ford Escort, Fiesta, Vauxhall Astra etc: 10mm, 19mm wide spacers
    12 x 1.5mm bolts (radius seat bolt) for VW Golf etc: 10mm, 19mm wide spacers
    14 x 1.5mm bolts for Porsche 924: 19mm wide spacers
    12 x 1.5mm bolts for (old) VW Beetle (5 hole): 25mm wide spacers
    14 x 1.5mm bolts for (old) VW Beetle (4 hole): 25mm wide spacers
    MikeS2’s given me the M14x1.5 is the thread pitch. Length is 27mm bit (many thanks Mike), but it’s the ‘bolt to wheel “face” that will need to be correct too. Currently the car is on VAG option Ronal R8’s.
    Or am I reading too much into this?
    Many thanks
    Ian
    93 MTMS2 Avant
  • Ian Simmonds
    • Jun 2005
    • 2858
    Having posted all that, what I'm after is adding 10mm wheel spacers, and need the appropriate bolts to go with it...
    VBR
    Ian
    93 MTMS2 Avant
