Spare wheel problem with coupes??
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    hello friends
    i have a problem¡¡ with my spare wheel in my coupe.
    the problem starts with my brake upgrades
    i am using 8x19" Oz Superturismos because i need them for suit the 385x36 brakes,and i am using 300x22 RS4 discs with the Porsche 996 Boxter S rear calipers at the rears... so the problem is that if got a problem driving my car what can i solve this if my spare 16" oem wheel cant fit in any of my front or rear brakes???
    solution : take a 17" or bigger wheel as spare for take the chance of use in the rears¡ ,now i did it ,one friend borrow me a 18" audi RS4 replica rim with 225/40 tyre ...and now the problem is that i cant use the 18" spare wheel in the original spare wheel position in the rear of the car as we use in our coupes
    it is really a problem¡ maybe i will have to install in this rim a smaller tyre like 205/45 ...
    someone had similar problem before with our coupes?
  • rj scotty
    • May 2006
    • 2195
    Use Run flat tyres ?
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • s2_wot
      • Aug 2006
      • 2178
      Maybe this will work
      Get yourself a 16" steel rim that will fit over the rear brakes. With a 205/55 R16 tyre on it. If it is too close to the brake caliper get yourself 1 x hubcentric spacer & 5 x long wheel bolts. 16" rim off an audi A4 ~ €20.
      Shane
      • jorge s2
        • Feb 2009
        • 226
        • Home: Portugal Current: Spain
        a 17'' wheel for the rear if you have a problem in the front wheel you take a 19`` from rear put on the front and put the 17``wheel on rear , too much work ??
        audi s2 aby red 1993 powreded by prj
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          ??? yo did not understand me¡
          the problem is with the coupe rear spare wheel location¡¡ maybe a 17" wheel will not fit well too in the rear spare wheel location very few space in the back there
          • vertigone
            • Nov 2009
            • 253
            • Country: France
            don't bother with spare wheel : take a repair bomb spray
            91' S2 3B Pearl White
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              A 17" wheel will fit ok. I've always used a 225/45-17" spare tyre. It is tight, but it will go. If it's too tight for you, just deflate it and carry one of those 5€ 2000psi cigarette lighter socket compressors.
              SS
              • jorge s2
                • Feb 2009
                • 226
                if the tyre is the right one on a 17 '' wheel it will fit , i understand you , if its too tight , you can use a215/45 or 40 17r tyre just to make the spare job.
