Hubs are available so with new bearing is there any reason why I can't just change the centre part of the hub and re drill/bore my discs until I can find/afford RS2 items?
will rs2 hubs fit into 7a carriers?
Tags: None
Spose the only problem would be getting clearance (inside of disc over outer diameter of the hub)
Bearings are the same, hat height will be different I'd of thought, I havnt got a tape
measure otherwise I would of measured mine for you, the Hub face must be at least 140mm though, coa of the 130 pcs and then half a bolt hole plus a little bit metal round the outside lolComment
front ones are straight fit AFAIK.
Rear ones are doable, need to mod the carrier quite a bit, on a couple anyway... not sure about the avant limo rear end, might be a straight fit too....
from memory you need to bore out the inner diameter to accept the larger 82mm bearing. Then turn the outer diameter to allow you to press on a strengthening ring. Sure there's pics on the forum somewhere...Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
