235/45/17 tyres ?
  • trevithick
    • Apr 2009
    • 174
    235/45/17 tyres ?
    Time has come again for some tyres and the chap in the tyre shop has a program on his computer that shows width/ diameter / mph etc of various types of tyre. He said have I tried 235/45/17. These are available in all the normal makes and I was wondering if anyone had tried them. Apparently they are a very close match to the originals. The old moneypit is running on 225s at present.
    Also do I stick with the Pirellis or do I try something else ?
    I look forward to your replys.
    T
    The older I get the better I was.
  • Simoni
    • 215
    • Country: Belgium
    RS2? I would stay with 225 due to the weird Dunlop problem they had back then.
    • trevithick
      • Apr 2009
      • 174
      Yep RS2. People who have the 245s (not the original Dunlop ones) have problems with them hitting the rear suspension but it made me wonder if 235s wouldn't ? The diameter on the 225s is slightly too small with all the associated problems, so I'm open to advice on the subject.
      T
      • bogreg
        • May 2008
        • 21
        • Country: Hungary
        The original 245/40R17 tyres were 628 mm in diameter, Audi recommended 205/55R16 winter tyres with 632 mm.
        The 225/45R17s are the closest match with 634mm. The 235/45R17 is simply too large in diameter with 643mm, not to mention that it is usually more expensive. I'd go for a stiffer sidewall 225. More width is not always more grip.
        • trevithick
          • Apr 2009
          • 174
          Many thanks, I'll keep with the 225s then.
          • Al Wyn
            • Nov 2006
            • 3746
            You and your crazy mad proffessor thoughts `again` Mark def stick with 225s try some Falkens
            S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
              Some guy on Audisrs has just fitted 235/40/17 on his RS2 I think he's a bit made putting such wide tyres on a 7J rim
              • Ross
                • Aug 2005
                • 3399
                Which falkens are those Al?
                I took the RS2 out for the first time in 2 weeks this morning, as there was a bit of a chill in the air... still - need to order some summer rubber, my Korean winter rubber is useless. Was thinking a set of Toyo T1-R's at ~320 for a set of 4... 225/45/17
                • anthonys2
                  • 3512
                  Try the faulkens 452/752 something like that i have them on my S2 on the 18s they very good tyres and best place to buy them is from camskill website hope this helps!?
                  • madpugger
                    • Sep 2007
                    • 1901
                    Mine are 18s, but I use 235 on the front and 225s on the rear because the 235 Goodyears rub the rear top arm. 235 Conti's did not rub though. Some 235s are wider than others (Dunlop are very wide and square from my Pug days) so its a case of trial and error really.
                    Le Mans 2012
                    Nurburgring 700
                    1995 S2 Avant
