Wheel Stud Conversion-Any disadvantages?
  • Phil Payne
    • Jul 2009
    • 328
    Originally posted by Jamo
    Change a wheel after converting to wheel studs and ask that question again
    What I always find interesting is that Audi fitted a single cross-head countersunk screw on some cars just to 'tack' the disc in place so you were only juggling two items in the dark and pissing rain on a muddy roadside instead of three. Why did they omit that screw on so many cars?
    Otherwise 893 012 023 (the legendary doobriefirkin) is your friend.
    • smirre
      • Sep 2008
      • 10
      or this:
      • Ian Simmonds
        • Jun 2005
        • 2858
        Originally posted by smirre
        or this:
        Blimey, that's an ambitious gap to fill with spacers...
        93 MTMS2 Avant
        • Colesy
          • Feb 2009
          • 2983
          I have a stud conversion with 15mm spacers and they are great overall, very easy to change wheels.
          The only disadvantage I can think of are if you want to change to wheels with different offsets as you would probably needs studs of a different length. Also it is quite hard to find a good set of conical nuts in M14/1.5 but they are around.
          I bought a stud conversion from Axis Motorsport as they are the perfect length for 15mm spacers. - http://axismotorsport.com/p35/Wheel-...duct_info.html The best thing about these is that they have a allen key hole so you can screw them in relatively easily.
          You can also get hold of 60mm & 80mm studs in the UK from a few places which you can then cut down.
          If anyone needs any 80mm studs I have 19 that I could sell but it would probably be easiest to buy them all new.
          Edit: Here's the UK place I've used, they stock all sorts of studs and post them out pretty quickly: http://www.speedshack.co.uk/
          • hibby
            • Apr 2007
            • 215
            or this:
            You have a nail in your tyre and you are wearing your wifes boots.
            1990 Cq20v GTi Engineering RE2400
            1992 16v 80 quattro
            2004 A3
