Anyone running BBS LM reps?
  • andyg plym
    • Nov 2006
    • 4646
    I am running some bbs lm reps and am trying to find the size of the centre bore.
    I am trying to get some hubcentric spacers off banbridge and he needs to know what size i need. I know the S2 hubs have a 57.1mm (i think?) but I need to find the size of the rim bore?
    I bought these off a forum member and are obviously 5x112 with et of 45 so i have been running 10 mm spacers but need hubcentric ones.
    Any help would be great
  • s2_bo
    • Oct 2005
    • 6067
    if they fit s2 hubs then they must have the same bore, if not you would soon know about it!
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • andyg plym
      • Nov 2006
      • 4646
      they are larger than s2 hubs bo hence why i want some hubcentric ones.i have spacers atm, i have efectively been running around with the wheels held on by just the 5 bolts and not the actual hub itself
      • rj scotty
        • May 2006
        • 2195
        Providing you take care when fitting the wheels and make sure they are perfectly aligned it ain't a huge problem, not ideal but not worth worrying about to much. Just take it easy till you sort some spacers/hub rings.
        My golf has run like this for 8 years.
        cheers
        rich
        BUT I DON'T WANT A NEW CAR!
        1995 S2 Avant, Volcano Black
        • andyg plym
          • Nov 2006
          • 4646
          cheers rich, trouble is they are a fekin pain to fit on and im sick of having wheel wobble! For the sake of 30-50 nuggets its got to be a wise investment!
          • rj scotty
            • May 2006
            • 2195
            To right. been meaning to get some hub rings for the golf for 8 years now
            The way I fit the golf wheels is to remove the centre caps and make sure the gap between the hub flange and the wheel is uniform all the way around. Not had to do this in the the dark at the side of the road when it cold and raining but I will one day.
            • s2_bo
              • Oct 2005
              • 6067
              If the wheel is wobbling it will eventually work the bolts lose, that could end in tears..
              91 S2 coupé - RIP
              • rj scotty
                • May 2006
                • 2195
                Yes I supose it could, a fair point.
                Get it sorted dude
                  measure the bore? if they are 112 pcd they will be 66.6 minimum as that is merc fitment.
                  • Acidburn
                    • 13459
                    best advice possible, listen to the error, just take one off and check with a tape measure behind
                    • BRY
                      • 3755
                      I have four of these BBS 12mm hubcentric spacers - if you want them let me know:
