avus replica
  • 80andyb
    • May 2011
    • 42
    • Home: England Current: United States
    avus replica
    hi all iv got a audi 80 with the 108 pcd, dose anyone know if i can get s2 avus alloys reps with that pcd?????if so where from????
    any help would be great cheers guys
  • Rusty
    • 18953
    Depending on what the stock offset is, you'd be better off getting some adaptors or just changing the hubs. I've never seen reps of either 5 or 6 spoke Avii...
    • DarrenM
      • Aug 2007
      • 1227
      Nope, I've never seen Avus reps in 4x108 either, its a bit of an awkward fitment. 4x108 is a bit limited i'm afraid unless like Andy says, you dont mind adapters.
      • 80andyb
        • May 2011
        • 42
        thanks for the replies,i thought it might be a long shot .ill keep my eye out for s2 hubs/brake set up.
        how much do you think it might cost for the front set up???i know for the rears i can use a4 discs mine needs changing anyway
        • Rusty
          • 18953
          Why not fit some Cario Bolero alloys, as they come in 4x108 and are often fitted to S2/4/6.
          • fourringsrus
            • Oct 2009
            • 239
            As said above 4x 108 is an odd one. I have spent the last two years looking for the Avus rep or the RS4 rep both in 18".The Avus does not seem to exist as 4x 108 but I have just recently found a set of RS4 18" with good rubber.I think that when I researched this subject of adapters it appears that 108 pcd is awkward to make an adapter to 112 like the 5 stud of nearly all later Audis.As said above you may be best off searching for a hub conversion set up or resign yourself to hit/miss finding something else on the usual web sites that might be acceptable
            Stuart
            • fourringsrus
              • Oct 2009
              • 239
              I think ref the Bolero rims , which are gorgeous , you will struggle to find them for sale very often and I believe that the 4x108 on the cabrio/coupe will be only 17"
              Good luck pal
              Stuart
              • M_GORDON
                • Oct 2008
                • 1295
                • Home: Isle of Man Current: Vatican City State
                I have seen one replicas but only from a AVUS mk2
                photobucket SUCKS
                • fourringsrus
                  • Oct 2009
                  • 239
                  Gordon, do you mean you have seen Avus reps with 4 x 108 pcd?
                  Even my RS4's are 4 x 108 but they are multi fit, ie; 4x108/4x100
                  • 80andyb
                    • May 2011
                    • 42
                    iv only seen rs4's with 5x100 and 5x112 there a nice wheel i could live with i take it the 108's are like rocking horse poo???
                    • Gompa
                      • Oct 2008
                      • 285
                      As stated above I'm almost sure you can't do 4x108-5x112 they would catch eatch other. Sure an engineer type can confirm. 4x108 bolero's are rare but do come up but they command a bit more of a premium. Simplest route is to hub swap that then opens you up to any number of 5x112 wheels from replicas to others from manufacturers like mercedes vw seat lambo etc
                      • DarrenM
                        • Aug 2007
                        • 1227
                        Me to, I've got 17" multifit A8 blades (Audi call them "12 spoke design") in same fitment on my 2.8cq. Not to everyones taste but i like them.
                        • fourringsrus
                          • Oct 2009
                          • 239
                          The 108 4 stud is a rare animal as RS4 but particularly in 18" guise, you will see 17" RS4 about more often.
                          • 80andyb
                            • May 2011
                            • 42
                            what to do what to do .at the moment im also trying to get a pair of s2 hub but thats not going well either
                            • fourringsrus
                              • Oct 2009
                              • 239
                              I've got a feeling that the S2 hubs (front) have something in common with 2.6/2.8 v6 front hubs, can't remember what but might be worth a bit of research.
                              May be to do with teeth number on spline???
                              Stuart
