RS2 Wheels Nuts Stuck...help
  • ian4455
    • Nov 2010
    • 787
    Has anyone had a problem with alloy wheel nuts on an RS2. I've just spent 4 Hours carefully drilling small holes along the edge on one nut to carefully split it in order to get it removed to take the wheel off the car.
    Now i have two other wheels that need removing with one wheel that has three nuts i need to get removed that have had the hex snapped off.
    Other problem is one of the locking wheel nuts (alloy) i have no locking wheel nut adaptor.
    What is the best way to get the wheel nuts removed, thinking of drilling the studs.
  • Ross
    • Aug 2005
    • 3399
    These are a bit notorious, I have no issues as long as they are copper greased and torqued on correctly using a decent wrench. Those buzz guns used by many tyre shops will destroy them.
    Also - make sure you have a decent socket, I've mangled nuts using a cheap tool to the point it just spins on the nut and then getting a decent deep socket on it it grips and pulls it right off.
    I had an issue with a mangled locking nut - afraid the method to fix it was a big drill and a few sessions letting it cool in between. Went through to the stud, and then used a stud extractor to do the rest. The replacement stud was a few quid.
    • mcandmar
      • Apr 2004
      • 5118
      We have had the same issues with them on Porsches, there a complete nightmare. First thing to check is that your socket is deep enough to bottom out covering the entire nut, other wise they will twist the end off and shear in two. A smear of copper grease stops them sticking however Porsche specifically tells you not to use any lubricant on them. In my experience if the threads or hex body start to look tired bin them. If they do shear the only way to get them out is to carefully drill them so they split, not as easy as it sounds. You have my sympathy on this one. Only consolation is there as soft as butter.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • willg54
        • Jun 2009
        • 2055
        as for locking wheel nuts...go to halfords and buy some locking wheel nut remover tools. about £14 iirc.
        they are left hand thread things that go on the outside of the nut. screw them on, use a breaker bar and turn them onto the head. eventually the bolt comes undone!
        easy! makes a mockery of locking wheel nuts...
        • ian4455
          • Nov 2010
          • 787
          Thanks I'll pop down tomorrow.
          • raccabuda
            • Aug 2007
            • 157
            Remove subframe, driveshafts and struts, chuck them in a skip and buy new from VAG.
            What could be easier?
            • s2_bo
              • Oct 2005
              • 6067
              I had the same on my rs2 ended up hammering on a smaller socket which did the trick.
              After that I binned them all and replaced with steel ones. Prob solved.
              91 S2 coupé - RIP
              98 S8 - Luxury barge
              • ian4455
                • Nov 2010
                • 787
                Where's best to get steel nuts and new studds ?
                • ian4455
                  • Nov 2010
                  • 787
                  Finally today success, wheels are now being re-conditioned. Should have them back tomorrow.
                  • Gazjen
                    • Oct 2008
                    • 223
                    There's a guy on ebay selling steel nuts for Porsche if you still need them, I need to order some for my Porsche wheels for my polo
                    URQ 20vt converted
                    80 quattro saloon with on going a V8 transplant
                    • ian4455
                      • Nov 2010
                      • 787
                      Thanks, take it 19mm ones will fit ? I think steel ones may be a better idea also, I'll need to source a set including four new studs.
                      • PaulJ
                        • Jun 2008
                        • 253
                        RS2 Broken Wheel Nuts, Just happend to me x 3
                        Yeah the very same thing although all 3 on the same wheel, All others are OK, Spent an hour or so trawling the net and found that Porsche list a 17.5mm holesaw as the tool to use
                        I've attached a clip I found on the net which is from a Porsch service bulletin.
                        17.5mm Hole Saw, Ha, More chance of finding new RS2 light trims !, Managed to find 17mm on the RS website so I've ordered a starett one and an RS home brew one, The RS stuff hopefully will be made with thinner metal and so a bit more clearance up the middle. I'll grind the internal offset teeth off and hopefully it will fit over the 14mm stud
                        Wish me luck !
                        Paul
                        1995 RS2 Nogaro
                        1971 Lotus Elan Sprint
                        1974 Lotus Elan+2S 130/5
                        • mcandmar
                          • Apr 2004
                          • 5118
                          And they say the Germans have no sense of humor. I wonder can you buy the "removal tool" from Porsche direct
                          • PaulJ
                            • Jun 2008
                            • 253
                            Got Them Off but more help required
                            Managed to use 2 different brands of hole cutter to get the broken nuts cut out, did not damage the wheel at all, Ended up cutting out 5 across 3 wheels, There is slight thread damage to the wheel stud caused by the inside of the hole cutters and I would prefer to replace these studs, Audi cannot find the part number for these, Does anyone know what length the standard studs are and I'll get from Porsche specialist ?
                            Cheers Paul
                            1995 RS2 Nogaro
