Wheel Adaptors
  • Dobby84
    • Feb 2011
    • 1169
    Wheel Adaptors
    Hi everyone.
    I have the opertunity to buy a set of 17" BBS RC041 7.5 at a very reasonable mates rates price.
    I know that they are BMW fittment 5x120 so will require adaptors to fit my S2 (5x112 I think)
    Has anyone used adaptors before or can give any advise how I could fit them. ie where to get said adaptors etc. My car isnt lowered yet but looking at dropping it a bit to suit the wheels.
    I do have contacts at a machine shop who could make some up for me but would require infomation on material spec/bolt typs etc for them to fabricate them.
    Also if anyone is a dab hand on Photoshop and fancies putting them on a red S2 that would be great.
    Also if I do buy these wheels I will have a set of RS4 wheels for sale.
    Cheers for any input guys.
    S
  • re2500
    • May 2007
    • 2185
    I think 5x112 to 5x120 adapters should be quite easy to come by. FK do quite a large range of adapters.
    What are the offset of the BMW wheels, as i seem to remember BMW wheels having quite a small offset, therefore combined with the width of adapters (15-20mm minimum) you might find hey stick out too much?
    Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
    "Difficult is worth doing"
    • Dobby84
      • Feb 2011
      • 1169
      I was thinking the same thing regarding them sticking out too far. My freind has them on a corrado and the just rubbed slightly but solved when he rolled his arches.
      According to a quick google search the offset is 41
      • andy10v
        • 5996
        Do you know what offset the wheels are? You will need enough space for the thickness of the adapters which will act like spacers.
        Sold ABY-stock
        • andy10v
          • 5996
          Too Slow.
          Sold ABY-stock
          • Dobby84
            • Feb 2011
            • 1169
            An internet search said that the offset is 41
            • re2500
              • May 2007
              • 2185
              are they 7.5" wide?
              I managed to get away with ET19 on a 7" set of wheels on a coupe with 205 tyres.
              Assuming a 20mm adapter will give you a ET21. Any more than 7.5" wide you might struggle. Because that extra 1/2" will push the lip of the wheel out about 6mm. the equivalent of a ET 15 on a 7" wheel.
              8" could go either way, a bit of a gamble.
              So i think you might just get away with it, they will probably sit nice and flush with the arches. you might need a little stretch on the tyres to reduce the scrubbin' maybe a 205 or 215 width?
              • Rusty
                • 18953
                Sorry but adaptors are for Polos, 'slammed' Golfs and those bafoons on the 'Chop Shop'. You're introducing another oportunity for the fast and heavy S2 to shed a wheel and cause severe damage and possible injury. Having nearly shed a wheel with some properly fitting wheels, I'd not touch them on the S2, unless it was a show car and was never going to be used in such a way that large loads and heat could be imparted into the hubs. However, it's up to you and so here's some impartial ramblings -
                For 8J you want ET30-35. Assuming you'd be running 225 section tyres, you'll still want something in this region to keep the tyre away from both the arch and the inner balljoint (225/45R17 are correct for the S2). OE Avus are 7.5J and are ET38 and can be used with 225 tyres without rubbing, but I'd want to push the outer edge out a little to improve looks and increase the track a little too.
                For your ET41, you'll have 3/8" / 10mm or so to play with (giving ~ET31). I'm not sure on the thickness of the hubs but they can't be far different to this. The issue you'll have is finding bolts that have suitably low head height to enable them to be recessed into the 10mm material for affixing to the hub.
                As you'll have to run studs for the wheels, I'd prefer to see the adaptors made of the same material as the hubs, i.e. a suitable steel, because they are effectively doing the same job and aluminium is just not a good idea for cyclicly loaded parts that are taking large loads.
                Overall, I think the costs involved would make a set of BBS LM replicas, or equivalent, a better overall choice, as fit will be 100% and you'll not be risking a wheel shedding disaster...
                Just my 2p.
                • Dobby84
                  • Feb 2011
                  • 1169
                  Cheers for that info.
                  I think the wheels would look really good on the car and will be slightly rare compared to my current RS4 wheels plus I cant really refuse the price my freind if offering them too me for.
                  Want to get hold of engineering drawings for the adaptors now to see if I can get them made cheaper than say FK or H&R (£135 a pair)
                  • Rusty
                    • 18953
                    A few things I'd be looking for-
                    • Similar OD to the BMW.
                    • C'bore 57.2mm to fit the Audi hub centre.
                    • 5 off 14mm clearance holes equispaced on a PCD of 112mm.
                    • 5 off 14mm clearance holes equispaced on a PCD of 120mm.
                    • Chamfer the inner edge of the c'bore to clear the hub radius, something like 5x45deg
                    • They must be hubcentric, i.e. they have a BMW sized boss sticking out to centre the wheel with a radius at the base and a small chamfer up to to improve fitting.
                    BUT, as Ive already said, they're not suitable for an S2 IMO and will cost quite a bit to get a full kit; £150-200 would be my guess for a set with studs, made from a suitable steel.
                    • Dobby84
                      • Feb 2011
                      • 1169
                      Cheers Rusty, Your opinion is always welcome and well received.
                      I was thinking a steel would be better rather than aluminium as I was wandering about the strength of the adaptors myself, although my freinds Corrado is running them with over 500bhp going through them and has never had a problem in the 4-5 years he has owned it.
                      My S2 (3B) is my daily drive and although the turbo has been upgraded and remapped ecu it is standard. It wont be running more than 300horses.
                      • Rusty
                        • 18953
                        A Corrado is a very light car compared to the S2 and unless it's been on track, you'll never really generate much load or brake temperature as straight line acceleration doesn't lead to much heat or lateral load. A mate's Golf track car is running stock S2 brakes and doesn't suffer from any brake fade on some really taxing airfield days; even with 996s, I have had fade on DS2500s after the same number of laps in a road going S2 with 300bhp.
                        My experiences have been on track where temperatures and loads are high and the resulting loosened bolts have showed themselves in both a road and track environment, both leading to some severe 'winking starfish' moments, hence my strong views based on some very close calls - a brake caliper falling for example! To a lesser extent, spirited road driving can also see higher temperatures and loads in an S2 because of the weight, hence why I would prefer someone to know the possible consequences of doing this sort of thing.
                        Shame you can't get the hubs re-drilled to 5x120 without doing the brake discs etc.
                        • Dobby84
                          • Feb 2011
                          • 1169
                          That is a very fair point.
                          Why cant the hubs be redrilled? Is it because the holes will clash with each other?
                          I assume a hub conversion is out of the question/too much effort.
                          • Rusty
                            • 18953
                            You'd just space them inbetween the existing holes but the discs would have to be re-done and any spacers would need to be custom to take into account the Audi to BMW c'bore etc.
                            • Dobby84
                              • Feb 2011
                              • 1169
                              Fair enough. Looks like the whole thing would be too much effort.
                              Suppose I could run adaptors day to day (cant afford heavy driving at the moment) and then put my current wheels back on for anything track based.
                              Probably wont bother now though after your information. Dont wanna run the risk of it all going pete tong. Shame I love those wheels.
