RS2 Studs Part Number Question
  • ian4455
    • Nov 2010
    • 787
    What is the part number for replacement Wheel Studs for an RS2 ?
  • saltinot
    • May 2004
    • 1946
    which studs? manifold? wheel?
    • ian4455
      • Nov 2010
      • 787
      sorry corrected the post.
        you can get suitable items from aftermarket - look for M14x1.5 studs - I expect that 50mm length is enough but you should measure to be sure
          Fit them with the twin nut and threadlock trick and you are golden... I converted my S2 hubs to studs a few years ago and never looked back
          • ian4455
            • Nov 2010
            • 787
            Not sure what you mean, thought the studs are pressed in from the back of the hub and have a spline with a button end to stop them from coming through ????
            Or are you meaning, remove the old studs. Tap out the Hub to 14mm and screw in a normal stud with locktite and fit a locking nut on the back of the hub ? If this is so did you remove you hub to do this ?
            • Al Wyn
              • Nov 2006
              • 3746
              Ian whats up with the studs? or is it the nuts youre after? nuts part no post 6 of this thread hth http://www.s2forum.com/forum/showthr...=rs2+wheel+nut
              S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
              • ian4455
                • Nov 2010
                • 787
                I need to replace 4 Studs due to not having the locking wheel nut socket
                having to get them removed damaged them. Also need new nuts due to being alloy and the rears being overtightened, suspect via an air gun when the new tyres got fitted.
                • Al Wyn
                  • Nov 2006
                  • 3746
                  I see mmm i will have a look in the vault and see if i can dig anything up on the studs bud... youve got your part no for the nuts in my last post
                  • ian4455
                    • Nov 2010
                    • 787
                    yes thanks, great i'll get some ordered as can't leave the car like this much longer. Needs to be back in the garage !
                    Do the studs screw out or are they pressed in ??
                    • Al Wyn
                      • Nov 2006
                      • 3746
                      Drawing a blank with the exeption of this unanswered question http://www.s2forum.com/forum/showthr...RS2+wheel+stud although you might know the length if youve removed one
                      • Al Wyn
                        • Nov 2006
                        • 3746
                        Just had a quick cross reference and these `seem` to be the ones but will need to double check http://www.design911.co.uk/fu/prod13...4-928-964-993/ night night
                        • ian4455
                          • Nov 2010
                          • 787
                          Thats great thanks for your help, not to badly priced. I'll get on with removing them tomorrow and check to see if they're 52mm in length. Hopefully be able to press these out in situ looking at the hub assembley. with the disks removed.
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            good luck Ian, it seems you have started with your left foot on the rs2 but hopefully it will get sorted.
                            • sam80quattro
                              • Oct 2006
                              • 1496
                              give the damaged studs a good wacking with a hammer whilst the wheel's removed and they'll fly out, to get them back in on the car your going to need to use a nut on the stud to pull the spline into place
