Will they fit??
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    Will they fit??
    A question for Avant or B4 Sedan owners, what ET do I need if I fit 8.5 x 18 wheels with 225-40-18 tyres? I really like these - http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_5076wt_1141 -
    Any info on these wheels or indeed pics would be good too .
    Russ
    Old Stuff Reborn.
  • Rusty
    • 18953
    IIRC, you need ET30 to clear the front steering arms, it really depends what tyres you want to run - 225/45 or 245/40, the latter will cause more issues, as obviously, they're wider. Have a look at Jamo's thread, I think he has/had some big wheels and also pixsaudisex2 has some wheels (Jamo's old ones?) on his RS2.
    • RustyNut
      • 1433
      Has anyone got any pics of 18x8.5 wheels fitted to either an avant or sedan with ET 30 offset? Need to get an idea of where they sit relative to the arches.
      Old Stuff Reborn.
      • RustyNut
        • 1433
        also, has anyone ever fitted a set of 8.5 x 18's with an ET of 37 before or are we needing spacers at this point? Unfortunately, every time a set come up for sale they're either too far away to test fit or they have the wrong or no tyres on them...
        Old Stuff Reborn.
          for 8.5j wheels Et must Et32-33 minimum eet37 will foul inside on steering arms and you will need 5 mm spacers.
          Also you will need the arches rolling at the front with ET 30, it's boderline with ET32-33 and most cars still need the arch rolling
          Pics mean nothing as alloys types vary in fitment, it's a case of fit and alter
          • Skull
            • 3506
            • Country: Slovenia
            et 33 is outside the rear arch, i tried the bbs rc and were a no go
            Audi Quattro WR
            • RustyNut
              • 1433
              hmmm, I think i've got to give up on the idea of fitting 8.5's then… So, and this question has probably been answered a million times before!, what is the max ET you can go to on an 8x18 rim without the need to do any mods? For reference Jamo, I always thought your coupe with the Mk1's was spot on, can you remember what thickness of spacer you used front and back?
              Old Stuff Reborn.
                15mm front and rear spacers on the Coupe and on the Avant. Gavs2 has pic of his ruby red avant with 18x8.5 all round with the 5x112 hubs, he notes his ET as well but again the problem really is the ET maybe the same the alloys are not.
                This thread was my bible when I 1st started out http://www.s2forum.com/forum/showthread.php?t=6974
                18x8 is a great fit to do ET35 and your laughing
                  8.5J ET35 will probably just clear the steering arm with a 225/40 tyre. I have 245/35 on a 8.5J ET32 with about 3mm clearance.
                  Depends a lot on the tyre.
                  Rear axle is the issue on the avant / saloon.
                  • RustyNut
                    • 1433
                    Error, got any pics?
                    Old Stuff Reborn.
                    • sam80quattro
                      • Oct 2006
                      • 1496
                      ive got 245/40/18 on the rear of my 80 saloon. the tyre is on the suspension arm lol but its ok it never moves
                        • 12431
                        Mine on 17" 8.5 ET35 has about 4 mm clearance on the steering arm from tyre so might just get away with it on 18's
