5x112 to 5x114
  • terrybullwon
    • Mar 2006
    • 8782
    5x112 to 5x114
    Has any one made any adaptor plates?
    Cheers James
    Chef
  • WabTheKing
    • May 2004
    • 2567
    nope but i was going to do this to conver to jaaaap wheels
    s2 is on m14
    japp stuff is usually m12
    if you re drill your hubs 114 pcd with m12 studs you still pretty much have the same amount of material at the edge and your orginal discs should still fit or worse case might need the holes enlarging by .5mm
    • WabTheKing
      • May 2004
      • 2567
      you can still revert back to orginal rims too, like the twin fitment rep wheels for audi vw with 112x5 and 100x5
      • andy10v
        • 5996
        I don't know about 5x114.3 m14, but 5x114.3 m12 looked ok.
        That is what I plan on doing when I do the wheel bearings.
        There are so many jap wheels avaliable, and at good prices.
        Sold ABY-stock
        • als2
          • Jul 2009
          • 809
          Wouldn't you get away with "wobble bolts" ? I know, the name is ridiculous, bit like buying a wheezy turbo, or a semi slack shocker, but the engineer principals behind them is sound. If i remember they've been about from the late 60s and a few wheel manufactures have used them. Been a bit easier if someone had called them Lateral Displacement Bolts or summit.
          Any hows i think they may have the ability to take 112 to 114 as long as you get the hub centric part bang on, that's where the load sits after all.
          just my 2 cents
          A
            I'd get the hubs machined to take studs on the 114 pcd mate
            • terrybullwon
              • Mar 2006
              • 8782
              Been offered 4 sets of Wheels from a local company problem is there jap fitterment they are instersted in getting into the vw/audi scene so maybe watch this space for a GB on some rather nice wheels !
              Chef
              • Jonnybravo
                • Aug 2008
                • 2051
                Just get Kev to make you some hub adaptors and get some centre locks on it James lol
