MTM 18" Cup 1's - Moving from 245 35 18's to 225 30 18's
  • PaulJ
    • Jun 2008
    • 253
    second that, you need to have a look at the rolling raduis of the tyres and compare to original, As a guide 245/40/17 = 225/45/17 = 225/40/18 = 225/35/19 roughly so working back 225/30/18 = 225/35/17 . . . As a guide only
    PJ
    1995 RS2 Nogaro
    1971 Lotus Elan Sprint
    1974 Lotus Elan+2S 130/5
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      Reading that post makes absolutely no sense saying that the original size of 245/40/17 is more like closer to 245/45/17. If that was the case then the width of the original construction would be even bigger than the comparison to the 225/45/17 that people downgrade to if keeping the 17inch wheel.
      I tend to believe more the manufacturer original specs rather than eyeballing an image on the forum.I didn't see any measurements there either. Just 'looks' small difference was the comment
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        If you are going to use 245/40/18 on an rs2 make sure you choose the ET wisely
          Ask any rs2 owner what audi told them to replace the original tyres with oh it was 225/45/17 as they were a size match there's even a pic from audi dealership on the forum showing this
          So believe what you like heh
          • UUUdirs2newcastle
            • Apr 2008
            • 655
            Oooh, add me me Facebook to see these sexy wheels!
            Fraser B'A Baracus Watson
              basic literacy seems to be an issue on this thread
              To summarise - the basic premise is that the Dunlop 8000s supposedly 245/40 17 were more like 225/45 17 when compared to other manufacturers / model sizes.
              So using the OEM RS2 tyre side as a base for further calculations is flawed as they are not really comparable to another tyre in the same size
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                #22
                Misunderstanding obviously. I know of the Audi dealers suggesting the 225/45/17. All I am saying is that if you want to go by the book and compare the actual radius from when dunlop were available, you use the 245/40/17 and you see that the closest solution for an 18 inch wheel is the 245/35/18
                  that's the point that Jamo was making, if you "go by the book" on this one you'll be way out as the "book" is wrong
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #24
                    actually just did the comparison to the 225/45/17 which gives a 639mm radius over (235/35/18),which is 629mm is still closer than the 245/40/18 is 653mm still.That is -0.79% vs +3% difference between the 35-40 tyre choise. Therefore even if i use the the 225/45/17 as a starting point, the best choice is still the 35 rather than the 40 or 30 for that matter for an 18inch wheel with a 245 width.
                    Of course the ideal would be the 225/40/18 as Jamo said(and misunderstood as i thought i saw 245 instead),but...
                    I dont want to be thick here, but the change from 245/40/17 to 225/45/17 by the dealer was done only because the Dunlop 245 was no longer available, and no other tyre had enhanced sidewalls to be able to be used with the 7inch stock wheel. It wasnt because the 245/40/17 and the 225/45/17 were 'pretty much equal' Also i dont think Audi ever recalibrated the speedos for that. I dont see the reason why we should go for the 225/45/17 for the original tyre calculations...
                    if it makes any difference, my speedo is much closer to the GPS now than it ever was on the 225/45/17.
                    • sam80quattro
                      • Oct 2006
                      • 1496
                      245/40/18 will fit on the rear of an rs2 without spacers if you press the front (wrong) drive flange into the rear hub. DOH lol
                      • GT500
                        • Jun 2006
                        • 2181
                        Fraser,
                        I have always had 245 35 18s on...
                        P Zero Corsa same as Lambo fronts. Best price so far are £251 each!!!!
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • UUUdirs2newcastle
                          • Apr 2008
                          • 655
                          Tyres
                          Originally posted by GT500
                          Fraser,
                          Corsa's.....frikkin Awesome!
                          I'm thinking when I scrub these to bald, I might give them a go?
                          I've driven home on the 225 30 18 Nero's and yes they are a bit harder than than the 245 35 18's, but the 245, 35, 18s I had were brand new Conti Sport contact 3's and I am sick of looking at them. They are a poular Mercedes Tyre, and even though the 2011 New C63 AMG comes with them standard, I bloody hate them!
                          245 40 18's will be ***** on my MTM 18's. I bought a BRAND NEW 245 40 18 P.Zero and it was far too much like a Krispy Creme Doughnut for me! (It's for sale anyone!)
                          Who gives a **** if your speedos off?
                          I like to drive my car, not worry about speed.
                          I like to listen to my car, not piss about with the Cd Player!
                          All the best!
