RH ZW1 17" and 320mm disc?
  • PiterS2
    • Nov 2009
    • 155
    • Home: Denmark
    Hi.
    Will the wheels fit over my 320mm discs?
    /PiterS2
  • Maro
    • Oct 2009
    • 45
    • Country: Poland
    Only with spacers I'm afraid...
    • dkw_dude
      • 555
      • Country: Norway
      I have ZW1 17x8 and 323 discs on my s2, no problems..
      Leif-Helge
      -91 S2 VEMS and Comp Turbo
      -12 B** 530XD Touring "S2 parts transporter, and daily driver"
        Easily over 320mm 17" fit over 330mm GT3, it's more about the caliper position in relation to hat height though
        • Ryss
          • Nov 2009
          • 233
          • Country: South Africa
          Agree.. Ive got 345mm under 17", but then you need to start watching off set of rims and discs and well as the addition offset need to clear the caliper and also the height of the caliper over the disc.
          Regards
          Ryss
          www.autostart.co.za
          • Maro
            • Oct 2009
            • 45
            • Country: Poland
            Depending what is the ET of the rims. I had 8x17 zw1 and 323 discs with Bosxter S calipers. There was a problem with the nuts from inner side. Without 10mm spacer nuts touched to the caliper.
            • PiterS2
              • Nov 2009
              • 155
              • Home: Denmark
              Thanks boys. ET 35 all 4 wheels.
              • dkw_dude
                • 555
                • Country: Norway
                Same as my wheels (from memory) think it was ET60 wheels - 25mm adaper =35mm ET total.
                Leif-Helge
