wich tyres for a +500Hp street car?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    hello friends, wich kind of tyres and sizes would you install in a +500Hp S2 coupe??
    the car is for street friendly use with some moments of inspiration,like the most of the people here i think.
    and i am not sure about the tyres sizes ,wich kind of tyre trademark ,or nothing,because i have never felt this amount of power.
    i would not want to lose traction or be dangerous with this amount of power...
    in our cars more than 225 or 235 wide tyres touch in the chasis true?
    what´s the best? to use Toyo R888 semi slicks with 225/40/28??
    Cheers¡¡
  • QuattroFever
    • May 2006
    • 1360
    Id say 235/40/17 and if you get the offset right and the arches rolled should be ok.
    Apparently bigger than 225 can spoil the handling though. I run 3071 and 225/45/17's with no problems. Can break free if you want but perfectly controllable so slightly wider maybe.
    Volcano ABY coupe
    Ant
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      they have to be in 18"....because my brake sizes
      in one multi-car spanish forum they says me about at least 245 wide... but in our cars i think it is a problem
      • QuattroFever
        • May 2006
        • 1360
        Yeh with 18 and 225/35 the sidewall will be shorter so it will be more responsive with 35/30 profile but when it gives you'd better be awake.
        So 245 would prob be about right... R888's would be fine, you don't have much of a rain problem there.
        Heard good things about bridgestones.
        Volcano ABY coupe
        Ant
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          and how many kms can be done with Toyo R888 driving 90% quietly and 10% WOT?
          at least 5000kms please....
          • QuattroFever
            • May 2006
            • 1360
            Couldn't say on lifetime never owned a set swapped from someone at a trackday and my pirellis scrubbed out the shoulders after 7 laps but r888 were still perfectly fine after 5 and could have gone least another 5 i reckon.
            Volcano ABY coupe
            Ant
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              maybe the Michelin Pilot supersport are for the same price a good choice with less grip but more durability? still being a very good tyres¡¡
              i dont want to die in a "bad" WOT moment
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                is it for your car? because yours is not 500+
                i have used with great success the following:
                225/45/17
                225/40/18
                245/35/18
                (maybe im wrong on the last ones, it could be 30 but i dont remember now)
                all were equally good, with the last ones making the steering a bit harder at times of parking. I cannot see any differences, but i have only been on the Nurburgring with the 225 ones and was happy with them.
                • Anagonda
                  • Aug 2005
                  • 70
                  Rolled archers and removed inner fenders(front) I have 255/35/18 on 9.5 inch rim. ET was something like 45 or 40 and at front I have(if I remember correct) 15mm spacer. At rear the same, but spacer is 20 or 25mm on each side.
                  At front you have to have spacers because otherwise it will rub on steering arm or the part on the strut. Don't know if the height on the steering arm is same on KW v3 as I have them.
                  • Bram
                    • Aug 2006
                    • 2582
                    235/40/18 worked on the S2 avant for me. Just take good and expensive rubber. No irritating noise when cruising and also no screaming tires when doing a WOT.
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      225/45/17
                      225/40/18
                      245/35/18
                      i am having problems in 2nd gear with new 225/40/18 Goddyear F1 Asimmetric 2...and "only" 400Hp and XXX torque
                      i dont want to know what could happen the next winter ...with a new engine
                      i see... and dont you have problems touching the front fenders in hard turnings??
                      thanks for the info Bram , we will see what i will use
                      • dest
                        • 4287
                        My S4 is ~500bhp, I run 225/40/18 Falken FK452's and have found them to be really good, especially for the price
                          245/35 18 is fine on the coupe, I run these on effective ET32 with no problems. I have Conti SC3s, they are very good but the sidewall are very soft and they wear quickly. Best tyres i have had were Bridgestone RE050s.
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            thanks for this info Alex good to know
                            • Mcstiff
                              • Oct 2004
                              • 504
                              I fit 245/40-17s on ET35s (rear 8mm spacers) with no drama or mods (H&R springs). I bet 265s could fit with K&Ws (relocated arms) and some fender massaging.
                              1995 1PissedOff90sigpic1991 USDM CQ 7aT
