Anyone use OE Avus on track?
  • Rusty
    • 18953
    Who uses them please? Any comments?
    I'm just re-jiggling my wheel and tyre stocks and as I'm lucky enough to have 314mm brakes that fit neatly under the 16" OE ABY Avus alloys, I was looking at track day rubber in 205/55 V and 225/50 R16 W - ideally 50 profile R1R Toyo or AD08 Yokos would go on there to provide wet and dry performance for a reasonable outlay.
    +ve = Very light compared to 17s, more compliant sidewalls, OE looks, readily available, more toelerant of camber and bumps.
    -ve = 'only' 7.5J, not ET35 (so track is narrower), not much ventilation for brakes.
    As far as I can see, the downsides are minimal and can be solved with some 5mm spacers (I swore I'd never use them) and cooling ducts but the advantages are too big to be overlooked really...
  • Dingo
    • Jan 2008
    • 229
    Im on the same setup (314mm brakes) and work great, I use conti sport 2's as there cheep and good preformance, I have 2 sets of Avus and use my old rubber for track use (works better at 2 or 3 mm anyway) plus as you said some 5mm spacers on the rear just to give it that bit of extra track
    And the big plus is the weight, a part used wheel and tyre como only weighs 18-19 kg
    • Rusty
      • 18953
      I tried trackday rubber last year and it was a seriously good idea on the S2. Just having to look into options to get my wheels & tyres sorted out.
      Yes, that's what I just thought of. The OZs that I'm selling to fund some tyres are about 19kg too
        I run 225/50 on my avus on track - they work great. Not as precise as low profiles but worth the massive cost saving over 35 or 40 profile 17s or 18s.
        EDIT: Forgot to add I run 15mm rear spacers, and 10mm up front
        • andy10v
          • 5996
          I used 225/50 16s on the track, worked well and a lot lighter than 17s (obviously wheel dependant).
          You could watch out for a set of early 100 s4 wheels, they are 16x8 et 45 iirc so would need spacers. Just watch for radial cracks!
          Error is that an updated spacer combo to what you had previously?
          Sold ABY-stock
            yeah i had 15mm all round but i swapped the fronts for 10mm as I wanted to balance the track front to rear - couldn't go any wider at the rear as 15mm wider at the rear was already scuffing the arch liners over bigger bumps when 3 or 4 up - (running HA/VA H&Rs)
            • s2_wot
              • Aug 2006
              • 2178
              Rusty because the 314 discs are externally vented there won't be much advantage to ducting them. 323 discs turned down to 314 will react much better to venting because they are vented internally.
              EDIT:
              Sketch for the cooling path in the different discs:
              Shane
              • mouse
                • Apr 2008
                • 375
                • Country: Australia
                I've done a couple of track days with 205/55s, no spacers, and have the 314mm front brakes.
                No issues with brakes but you really notic the lack of grip around sweeping corners and the fronts really want to roll onto their sidewall and scrub the shoulders very quickly even pumped up hard. Wider and lower profile than stock would definitely help.
                • Rusty
                  • 18953
                  Track tyres have much stiffer sidewalls and 50 profile is ideal for me. 16x8 are surprisingly rare...
                  • andy10v
                    • 5996
                    Sorry those early wheels should be 16x8, typo
                    Sold ABY-stock
