Bulge on a continental SP3 tyre. What to do?
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    Hi guys,
    i have noticed a small bulge on my of my front conti's yesterday. They tyres are fairly new, having about 6.5mm of thread on them, so im wondering what my options are.
    I have an appointment with the shop that fitted them tomorrow for a wheel alignment. Should i ring them today and ask for a replacement? Should i get a new one, and will that be a huge difference being 8mm from new?
    Is there any warranty on these kinds of problems?
    thanks in advance
    Vas
    Originally posted by A80Avant
    Hi guys, i have noticed a small bulge on my of my front conti's yesterday. They tyres are fairly new, having about 6.5mm of thread on them, so im wondering what my options are. I have an appointment with the shop that fitted them tomorrow for a wheel alignment. Should i ring them today and ask for a replacement? Should i get a new one, and will that be a huge difference being 8mm from new?
    Is there any warranty on these kinds of problems? thanks in advance Vas
    I presume the bulge is on the side wall. This is a sign that the plys on the sidewall have a) separated and b) leaked internally to allow air into the separation. As a result, the tire is damaged and dangerous. (Did you recently hit a rock or a pot or something (BTDT on hitting a rock and separating the side wall on a Conti winter tire, back in 1990 on my 1986 Jetta Carat).
    Tire warrantees do not necessarily come with the tire. Often they are sold separately. In my case, I had not been offered any insurance/road hazard guaratee, and ended up having to replace the tire out of pocket, even though it only had 250 km on it (Yes, just 250 km). I was *not* happy. (I did keep the tire on a rim as a last resort spare since it still held air, despite the bulge).
    Good luck.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      thanks,
      i have emailed continental UK and ill get in touch with the shop to replace it tomorrow as well. Hopefully i may get somewhere with this..
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        Update
        im paying for a tyre tomorrow, 170GBP fitted, and the old one is going back to continental for inspection and perhaps an independed inspector as well. However, most of the times it turns out that there is a reason for the damage rather than a manufacturing error.
        Looks like the occasional bump on the road is quite costly now... I seriously think i may need to go to a higher profile tyre again, although i cannot see much difference to a 225/40/18...
        anyway, we shall see...
          I noticed a small egg in the sidewall of one of my SC3s too Vas, when I took my BBS off for the winter. MOT man missed it unless it happened on the way home from the test centre - seems unlikely I didn't notice any nasty bumps or anything. Car hadn't been driven since then.
          I bought part worns, with 6mm tread so annoying as they have plenty of meat left.
          The SC3s have really soft sidewalls, I think I will revert to Bridgestones or try some P-Zeros next time. Michelins are just too expensive.
          • WabTheKing
            • May 2004
            • 2567
            i have loads of problems with front bentley gtc tyres de-contructing on the inner wall structure. its due to the weight of the car tyre manufactures havent got them right yet.
            always fun explaining to a customer........ yes i know you drive very carefully and you have only done 10k in two years and yes there was still 5mm of tread left, but your tyre is still f***ed sir.
            found that the budget tyres on 275/35/20 at £160 per pop are much better value that the pirrelli's which last no longer at £360+
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              yes i see that now as well. Didnt have these problems with SC3 before.
              Probably cheaper to go on 225 next time,and definitely try another make!
