Coupe offset
  • RoscoS2
    • Aug 2004
    • 190
    Coupe offset
    Hi Guys, just wanted some advice on wheel offsets, I have a 16v coupe and the 4 stud wheels (I know it sucks!). I have been looking for wheels for some time now on ebay and have come across some cheap Azev A's that just need a refurb and some decent tyres (toyo's my choice). These wheels however are ET35 and on my original wheels it says ET37, now would these fit given there is only 2mm difference, or am I just making up my own rules....?!?
    Could anyone confirm what the offset is for the 16v coupe and what other car's are likely to share the same offset VW/BMW?
    Could this ET35 on ET37 be overcome by using spacers?
    Rosco
  • RIX
    • Jul 2004
    • 229
    • Country: Denmark
    they will fit fine if they are not bigger then 8" wide,if you put a spacer on it will reduce the ET,so the 2mm spacer will give ET33 not ET37
    REGARDS
    RIX
    • Crawford_S2
      • 1555
      Agree with RIX, the offset wont be a prob, i run a ET35 et on a 7.5 x 17 and wish i had a 10 mm spacer to make the back ET25 would look better!
      Ragusa Coupe gone!
      • cartechnik
        • Apr 2004
        • 23
        hi forge have very nice 10mm and 15 mm spacers including studs and lock nuts
        • RoscoS2
          • Aug 2004
          • 190
          Great news, thanks lads. I think i'm gonna wrap them in some sticky toyo proxes tyres from mytyres.co.uk.
          One more question is there a site for conversion or could anyone tell me what size tyres would suit these wheels best, e.g. keep the same rolling diameter as to not play with the speedo readings?
          I currently have the stock 10 spoke 16v alloys with 205/60/15's and new wheels being 7.5 x 16 Azev A's.
          • Stick Insect
            • Dec 2003
            • 2338
            This may help.... Posted before
            http://www.miata.net/garage/tirecalc.html
            David
            • 90quattrocoupe
              • Nov 2003
              • 771
              You should have no problem with a 225X50-16 tire. I run that size on my coupe and no problem with anything rubbing.
