hi guys will a 9x17 rim et30 fit a standard rear [ not lowered ] coupe and if so whats the best tyre size? ta
will 9x17 fit at rear?
Yes it will fit fine. Tire size depends if you want stretch or not. I like it, so i would use 225
i have 9,5x18 with 225/35. Fits perfect.
See tirestretch.com for pics of various combinations.'10 A5 Coupè 2.0TFSI REVO
90 quattro
X- 91 S2 Coupè
467hp, 670nm! -
My friend has 9,5x17 ET31 with 235/40-17 in his S2 coupe and it fits really nicely and does not come out of the arch. I'm going to have the exact same dimensions next summer on my own. Tie rod end will be very close to the rim with these numbers. With 9x17 ET 30 you'll have 7-8mm more clearance inside to the tie rod end and the outer edge will be inner some 5-6mm.
Btw it will definitely look stupid without lowering...-Comment
the wheels are 8x17 et32 at front and 9x17 et30 at rear they have 215x17 on at mo so a bit of a stretch going on
so you think it wont look right with it not being lowered?
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
