Ok, here is the deal. I have got a chance to buy a set of Brock B1,s that are 10x17 ET 20. The Girl (!) that has got them has had them on a S2 coupé with 235/40/17 i think. If i was to squeeze a set of 225,s on them could i get by without roling my arches? Here are a few pics of her car.
10x17 ET 20
Tags: None
The 235's on there now look pritty streched. It probably would fit but you would really need to slightly roll the lip on the front archesComment
Its the rim width that concerns me along with the very low ET... Dont really want to roll the arches as i still want to be able to make it standard again, thats why i wondered if a narrower tire would help.Comment
Anyone else got any input on this before i potentially throw my hard earned cash down the drain?Comment
Fish - I have 8.5x17" et 13 Borbet As on my coupe and the car is lowered on KW coilovers. Whether the wheel catches the arch lip is largely down to how low your car is. I had to have my lips folded in to avoid rubbing under suspension compression (albeit the car is pretty low). The stretch on the tyre makes a big difference too. You would have to run a stretch like that shown on the pics you posted otherwise the tread pattern will sit outseide the arch (which looks bad and could get you pulled over).
The other thing is your turning circle will be limited. Regardless of stretch I would imagine a 10 would rub on the inner arch liner at full lock. My 8.5s do but again it being low doesn't help. Also, watch out for clearance from the inside of the wheel/tyre to the stearing arms on the fronts. I can only just get a finger between my tyres and the KW arms...
I think the key thing here mate is that you buy a 10" rim and run stretched tyres because of the way it looks. Definitely don't do this if your primary concern is handling.
Just my 2 pence, hopefully some of this helps
John
PS - I personally think the black coupe looks great on the BrocksComment
Thanks alot mate. My car is lowered on konis and H&R springs but i don,t know how much. It´s not violently low though. The reason i dont want to roll the arches is that i really want to be able to put it back to standard specs... I am thinking that 225,s should slip in under the arches, i hope so anyway=) you can look at my car as it is today at www.garaget.org/fish is your car alot lower than mine?
Cheers / KrisComment
Kris, first of all your car looks great!
Mine is lower but not by a massive amount. The beauty of the coilovers being that I can raise it bac up when I take it too far.
All I did to my arches was to have the internal lip of the arch folded back against the outer. This way you get increased clearance within the arch but it doesn't affect the 'standard' look of the arches on the outside.
Here's a couple of pics for you to see.
I've actually wound it slightly lower again since these pics. You can see how the tyre choice is crucial to ensuring the clearance to the arch is maximisedComment
I think youl be alright on H&Rs with those wheels, your car will sittt slightly higher on the front and slightly lower on the back than in those pictures.
You dont gain much by rolling the arches IME, as the lips are already folded up a bit (are on my coupe anyway).
As marshall stated you may want to do a calculation using your current wheels width and ET and the distance to the steering arm to make sure that 10J and ET20 will clear the arms, i have found that KW's do have less clearance though...
My gut feeling is that you'll be fine, they look fine on the car in the pic, and at least you know its possible......Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
"Difficult is worth doing"Comment
Fish, i have a few pics of your car on my PC, very nice looking car, and will look ace with the Brocks IMHO!!!
Your car isnt as low as marshall's, or the car in the first post, so you should have plenty of room, keep the turbo spokes for the track tho, just incase the brocks scrub a little.
Thanks guys, i really appreciate it! Marshall, your car looks fat as ****! I have bought them anyway, going to pick them up this weekend =) If all goes bum up i can always sell them again and stick with the porker twisters, as i really like them aswel but feel i need a bit of a change this summer. Not gonna sell them anyway! My main concern is steering though... But i hope to be quite ok there too. Wish me luck=)Comment
The wheels are here! Will post pics later.Comment
