Strange pulling theory
  • scouser_75
    • 306
    OK. So everytime I let go of my steering wheel the car shoots off to the left. This had been happening for quite some time - even after I'd taken it to a couple of alignment places. Was told by one of em that something (can't remember what!) on the underside of the car was bent. I thought "sod this" can't afford to change anything right now. I can live with the pulling
    Then recently, someone suggested a "great" place in North West London to go to sort out the pulling/shooting off to the left problem.
    The guy spent an hour loosening the bolts. He yanked em. Pushed em. Pulled em. And eventually heated em up
    Another hour later, he had finished.
    "ere u go mate. Now if it pulls to the left again, it aint your alignment, its sumfin else". Now, that'll be a hundred quid. Cheers :mischeif:
    "cheers mate. I'll take it for a test spin and if it pulls I'll bring it back".
    Off I went with all fingers crossed. But the second I let go of the steering wheel off it shot to the left.
    "FEEEEEEEEEEEEEEEEEEEEECK!"
    Took it back.
    "Mate. It's still pulling like Kylie in the buff".
    Now to cut a long story short... and to eventually get to my point.
    The guy told me that sometimes one tyre can be heavier than the others and thats what can make a car pull - not the alignment. I told him that all the tyres are the same make and model. He said that this didnt matter as one batch of tyres may just be heavier than another.
    I thought "this man is chatting the most unbelievable amount of crud".
    But he changed the front 2 tyres around. And guess what??? He was right. The car started to pull to the right this time
    Has anyone heard of this?
    Weird weird weird weird
  • Stick Insect
    • Dec 2003
    • 2338
    Yup, I have it at the moment on the Mondy, the tyres are directional and can't be swapped.
    It is true. I need some new tyres and this should cure it. Usually does. If tyres are worn this can affect things as well ( as in my case).
    I thought you meant a theory about pulling women, I didn't expect to see a post about tyres!
    David
    • scouser_75
      • 306
      MWAAAAH HA HA HA HA HA :mischeif: :mischeif: :mischeif:
      My trick worked - people were mislead into reading my post :mischeif: :mischeif: :mischeif:
      David, I have as many theories on pulling women as our cars have miles to the gallon
      Alps
      PS What happens if you swap around directional tyres???
      The guy who did mine said it doesn't matter as the only thing they're there for is for water spray to be directed in a certain way!!!
      • A1QSHIP
        • Aug 2004
        • 975
        Pulling Right/Left
        Alps
        Many directional tires have a different compound on the outer edge of the tread which is designed to only work well in a certain direction.
        The Acrua NSX has a different tire for each corner of the vehicle. Here at work we have a Hunter GSP 9700 tire balancer which will also measure "Road
        Force Variation". It has a drum about 1 foot in diameter which is pressed against the tire tread with a force of 800 lbs. This is done with the tire mounted on the balancer. This measures the compliance of the tread surface, telling the operator if there are any "hard spots" in the tread. These spots are ususlly the results of tire construction that is, where the belts of the tire overlap. Many times a low profile high performance tire with excessive road force variation can be remounted on the rim to lessen this effect. The tire machine will also measure the force to the right or left that the tire is "pulling" , making the drum move laterally against tread surface.
        The problem of tires causing a tire pull is not at all uncommon. With a vehicle such as the audi coupe, the alignment spec for front wheel caster is set to a value which is great for tire wear & traction but not for high speed stability. This lack of front end caster makes the Audi susceptable to a tire which due to construction or damage has a tire belt that causes the tire squirm laterally against the road surface. Sometimes, tires are replaced to get rid of a vibration or excessive pulling/drifting. This problem is more common in less expensive brand tires and is almost never seen in premium brand tires.
        "Nulla tenaci invia est via"
        • mcandmar
          • Apr 2004
          • 5118
          Seriously, every Audi I’ve ever driven has pulled to the left, New tyres fix the problem for a little while until the wear in. When changing the front sub frame bushings I played around with the position of it in the car and managed to get a majority of the pull out. It still slowly creeps to the left when you let go but your not driving along holding the wheel to the right any more.
          Dont change directional tyres around, they are designed to rotate in one direction for a reason. Think of how a tyre squats under braking and rises with acceleration. Change the tyres around and the dynamics work the wrong way then.
          Took it back.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • scouser_75
            • 306
            OH OH. Best get those tryes changed around first thing tomorrow.
            As for the pulling. My one doesn't exactly pull to the left... It shoots to the left when you let go of the steering wheel!
            And boy do I understand "...driving along holding the wheel to the right..." Tis good to know Im not the only one having to do this!
            • s2-1.5bar
              • Sep 2004
              • 193
              • Home: Lithuania Current: United Kingdom
              Hi
              When I fitted brand new 4 directional tyres all same size and make they seemed ok when I bought them. But the lad who put the on to alloys gave me back one as it required a lot of weights to balance. I spend 30min explaining to tyre retailer what the problem, so he changed the tyre. Sometimes during productions seemingly tyre compound could vary.
              In your case, I think, u need toi check bodywork geometry. It could be that body of the car-front end needs pulling a bit to get right. Even if the car didnt have any accidents, by using hard suspension, body seems sometimes during the time to go off. I had the same problem with my ex KR golf running on adj koni's.
              Andy
              • curlyks2
                • 1069
                "like Kylie in the buff"
                Got that far and completely failed to notice anything else on the page
                Ck.
                PS Someone had to say it. Might as well be me since I've got tickets to see her in concert (again) next year
                Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                • Stick Insect
                  • Dec 2003
                  • 2338
                  What 6?
                  David
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    That many!
                    SS
                    • scouser_75
                      • 306
                      Originally posted by Stick Insect
                      What 6?
                      David
                      No. I wish. In my case, 4
                      • Keeper of The Kitten
                        • Dec 2003
                        • 2317
                        Don't buy that theory about directional construction. Tread blocks for water dispersal, yes, but not the structure. You do see slicks marked directionally, in fairness, but I know some dyed in the wool racers who used them both ways around without problems! It is true that tyres take a "set" once they've been used though, which might explain why slicks are marked - so you continue to use them in the same direction throughout the life of the tyre. I'm running tyres which only have inside and outside orientation, so the direction of rotation is not relevant, but I would tend to only swap front to rear and not side to side for the rotation reason.
                        Variations are entirely feasible, tyres are still virtually handmade (although a lot of the work is done by machines the tyres are still manhandled and loaded onto machines manually). As for the NSX having four different tyres, that can only mean one thing: the tread pattern is directional and asymmetric, and the front tyres are smaller than the rears.
                        Pulling women? Try pink hair, then shave it all off!!!
                        __MDC__
                        Martin Cutting
                        • scouser_75
                          • 306
                          Thanks KOTK
                          Well, after all the hassle, I now have a flat tyre so will have to change it - like it or not
                          As for the pink hair thing - I've already booked myself into the hair dressers across the road Now just to wait for the ladies
                          • s2-1.5bar
                            • Sep 2004
                            • 193
                            [QUOTE=mcandmar]Seriously, every Audi I’ve ever driven has pulled to the left, New tyres fix the problem for a little while until the wear in. When changing the front sub frame bushings I played around with the position of it in the car and managed to get a majority of the pull out. It still slowly creeps to the left when you let go but your not driving along holding the wheel to the right any more.
                            Pulling to the left could be explained: all roads surfaces in UK have a small slope (gradient), to the left, so there is no standing water on the surface.
                            The car will pull very slightly ti the left on motorways, just because of that.
