Wheel PCD
  • SE_30
    • Apr 2010
    • 1114
    • Home: England Current: Israel
    Wheel PCD
    I've managed to buy a set of Azev A wheels, the hurdle is they are 5x110, how big of a hurdle if at all am I looking at here to make them fit 5x112? they were cheap as chips so grabbed them..
    Stuart
    B2 90 quattro with boost
  • driftin jo
    • Sep 2007
    • 2222
    What's the ET of them ? If it is large, say 50 or so, you could make adaptors for them,
    the other option is to remove the hubs and drill and tap the new pcd in them.
    • re2500
      • May 2007
      • 2185
      Plenty of people manage to fit different PCD wheels, as far as im aware you have three options
      Whats the offset? If the offset is high, then hubcentric spacers would be your best bet i'd say, as they will lower the ET (space out the wheels)! You bolt them on to your 5x112 hub using counterbored bolts. and the spacer has offset 5x110 threaded holes to bolt on your wheel.
      The other option is to have your hubs redrilled (you will end up with 10 holes in each hub 5x110 and 5x112) you will also either have to redrill your brake disks or slot the holes in your discs. (this option is the safest if the offset of the wheels is close to what you want. But a bit of a pain to get done as you would need to remove and split all your hubs.
      Failing that then wobble bolts (offset conical seats on the bolts) would make up the difference, it the cheapest and easiest, but IMHO wobble bolts are total crap and wouldnt put them on my nan's micra.
      (My nan doesnt have a micra, she's registered blind and cant drive, but the principle remains!!)
      Whatever you do make sure the centrebore is correct, or get good quality spigot rings! Good luck
      Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
      "Difficult is worth doing"
      • Rusty
        • 18953
        Depends on the performance and use of the car really. For a show car, most things go, for a mild road car, wobble bolts are an option but as above, they're sub optimal at best. Proper adaptors are fine but cost a fair bit and need enough offset to take about 20mm thickness, redrilling the hubs requires the discs being modified a little too (take the holes out to 16mm or have them completely redrilled). Don't forget, you'll need some new wheel bolts too.
        Another option is to get 5x112 wheels, clean up the current ones really nicely, sell them to a Golf 3 or 4 owner and make a decent profit. Hey presto, properly fitting wheels at a sensible cost. Work on the hubs or adaptors will cost a few pennies, so worth doing your sums first.
        • SE_30
          • Apr 2010
          • 1114
          There ET35 so no good for spacers / adapters. The wheel bearings and discs have zero miles on them as seen in the pic so don't fancy replacing the 4 bearings and modifying the discs to suit. Performance wise we're talking 450 - 500 bhp so wobble bolts are out the window, so it looks like option 3. Re-con them and sell them on for a small profit and buy the correct PCD, job done and no risk of my wheels parting whilst driving. Thanks for the replies gents
          Stuart
          • 90quattrocoupe
            • Nov 2003
            • 771
            deleted
            • martinws
              • Oct 2008
              • 917
              I have heard of wheels having the bolt holes filled in, machined flat then re bored. It was in PPC a year or more ago i think.
              On another note- is that caliper upside down?
                Yep bleed nipple is at the bottom, need to swap the x-over pipe and nipples if the calipers haven't been put on the wrong side
                • SE_30
                  • Apr 2010
                  • 1114
                  It certainly is upside down I realised that after taking the picture. I was rushing to get the car ready for the trailer and working at 100mph..
                  Stuart
                  • Ruffiano
                    • Sep 2007
                    • 1458
                    if it is only 2 mm difference you can use "wobble bolts"
                    they also work for mounting 5x114.3 wheels on audis/vw
