Stance, offsets stud pattern swops for B4 discussion
  • Sleeper_Avant
    • 2372
    Compomotive sell sleeves for their wheels, although having a set "made" isnt the end of the world
    we had a few sets dont for the late STi imprezas i converted to gpA spec with oddball stud patterns (STi has different stud pattern to non STi belive it or not!)
    the ones on my saff i had to buy, they were just a "push" fit, although they are only needed for extreme forces of forest stages with BIG jumps
    • Sleeper_Avant
      • 2372
      Alex, just noticed you posted the important numbers with the pics of the CH`s, cheers for that! thats what i was after
        Haha not just blatant wheel whoring
        I would go a bit lower but don't wanna lower the roll centre any more. Stupid mcstruts
        • Sleeper_Avant
          • 2372
          well these wheels against the car in question
          18" ones off my A4 235 40 18 tyres
            They will look awesome in white
            • Sleeper_Avant
              • 2372
              i know mate
              this means buying S2 front hubs, and im NOT paying £300 for a pair of hubs to put a set of wheels on a friggin car!
              unless the s2 front stub axles will go into the poverty spec 4 stud bearings and carrier/hub?
              HELP!
              • philj
                • Feb 2010
                • 377
                There was another set same as the white MO flat flaced on ebay last month going for £300, nearly caused me to give up the 5 stud conversion part hunt.
                Assume by stub axle you mean drive flange/wheel hub?
                If its a v6 with the bigger bearing housing, an s2 flange will fit as they use the same bearing. Audi 100 flange may also fit too (can anyone confirm?)
                  The hub will fit into the larger hub carrier as above, using an 82mm bearing. So V6 or 20v hub carriers can be used
                  • Sleeper_Avant
                    • 2372
                    so front hubs/uprights need to be V6 (2.6/2.8/Quattro or any?) or S2 82mm bearing
                    drive flange/knuckles can be 100/A6 or S2 that need to be ??mm to fit inside the bearing........... how many splines for the driveshaft?
                    was looking for the Sooty thread but couldnt find it, sure it was on there!
                    Cheers, Sean.
                      You can use S2, V6 or 20v hub carriers. Later S2 carriers have 14mm bolt holes. Early S2, V6 and 20v have 12mm bolt holes. Same bearing. S2, V6 and 20v have the same outer CV spine fitment.
                      What is the PCD of your gearbox output flanges on the 2.0?
                      That will determine what driveshafts you can use, but I think probably V6 or 20v front shafts will work for you.
                      So you just need to sort out the hubs themselves. I only know S2 ones will press right in, not sure about 100 or 200 etc but maybe they will work.
                      HTH
                      Alex
                      • sam80quattro
                        • Oct 2006
                        • 1496
                        ive put the bigger 20v cv's on the end of my b4 16v quattro shafts and all is fine
                        • Sleeper_Avant
                          • 2372
                          to get 5 stud wheels Sam?
                          sounds obvious but i have to ask! lol
                          OOOOOOOOOOOOOOOOOOOOOOOOOHHHHHHHHHHHHHHHHHHHHH
                          i dunno what to do, BIG flat faced compomotives or 5 stud conversion and fit my A4 18`s in white
                          • sam80quattro
                            • Oct 2006
                            • 1496
                            i went rs2 hubs, so 5x130..
                            gotta be the mo's
                            • Sleeper_Avant
                              • 2372
                              thats what am feeling to be honest!
                              Can anyone do me a photoshop? lol
                              PLEASE!
                              • Sleeper_Avant
                                • 2372
                                Alex,
                                i keep forgeting 20v isnt always S2 lol cheers!
                                Cracking info so far, Thankyou
