Wheel choices and recommendations
  • Monkeymagic
    • Mar 2012
    • 3419
    When i fitted my KW's to my S2 coupe the 17 inch Bolero rims ( from a B% A4 i believe) hit the steering arm. To ver come this i fitted 5 mm wheel spacers. However since then i get a slight steering wobble which is more pronounced at times and between 45/60 mph.
    I suspect it is the wheel not sitting quite right on the hub due to the spacers.
    Anyway I need to get the boleros refurbed and a new pair of rear tyres. So i'm thinking that will set me back about 450 quid. Plus then the expense of getting some proper hubcentric wheel spacers/wheel nuts and balancing posibly another 150.
    I'm starting to wonder if it would be cheaper and less hassle to get some new rims.
    I would love some original avus wheels but am limited to 17's now as I have 323 discs.
    What wheels do people recommend??? I love the look of mine but just want a set that have the right off set that can be simply bolted on without messing about with wheel spacers etc.
    Also if anyone has any genuine wheels with or without tyres in mint condition let me know. thanks Steven
  • s2_wot
    • Aug 2006
    • 2178
    urS6+ Alloys are the best looking OEM 17" for an s2. Correct fitment too
    Shane
    • Monkeymagic
      • Mar 2012
      • 3419
      Wheel choice is a personal thing. I cant say I am a fan of those. I like BBS LM's but the price is incredible for BBS in general. thanks for the suggestion though.
      • Monkeymagic
        • Mar 2012
        • 3419
        I also like the idea of lenso bsx with a gold centre but not sure if it's too retro???
        • Monkeymagic
          • Mar 2012
          • 3419
          • Monkeymagic
            • Mar 2012
            • 3419
            • re2500
              • May 2007
              • 2185
              You wouldn't get away with Avus either I'm afraid. I had the same issue. My BBSs were ok thankfully, but last week when I got some new goodyears fitted ( that turned out to be much wider despite being the same size as the pirellis that came off!!) the tyres just touched the arm and trackrod end.
              Before i got the car aligned I got round it by loosening the hub to strut bolts, pulling on the strut and doing them up again, it pivoted the hub enough to give me an extra couple of mm. May be worth a try.
              "Difficult is worth doing"
              • Yaz
                • May 2007
                • 445
                Hi Steven! I can get Lenso BSX. In fact I want them myself for my A100 Avant, they do some really good fitments.
                Let me know if you want prices.
                Another nice wheel I like is the Audi S4 V8 from models around 2003, this one: http://www.google.co.uk/imgres?imgur...9QEwAw&dur=262
                1992 Audi 100 2.8 Quattro
                1993 Audi Cab 2.3
                1995 Audi URS6 Avant
                1999 Audi S8 D2 FL
                2005 Skoda Octavia Elegance Variant TDi
                2012 VW CC BlueMotion Tech DSG
                • re2500
                  • May 2007
                  • 2185
                  That's hot!!
                  • Colesy
                    • Feb 2009
                    • 2983
                    A lot of people use 10-15mm hubcentric spacers which open up choices to wheels with ET's of ~45. I guess the 5mm spacers weren't hubcentric and this is why you had wobbling?
                    I've been quite unorthodox with my wheel choices with these at the moment:
                    S6 Avus should be a straight bolt on with an offset of ~35 these are quite hard to find though, OEM S4 & S8 wheels have offsets of ~45 so require spacers unfortunately.
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      yaz happy to put more money your way. get me a price for some lensos with tires. was going to call rimstyle but Will hang on. i don't want to mess about with spacers though if i can avoid it. cheers mate.
                      • Yaz
                        • May 2007
                        • 445
                        Ok i'll contact my Lenso supplier. The beauty with this also Steven is that you can specify the offset required to suit your car. So firstly, what size in diameter and width do you want and offset. Oh and don't forget the colour!
                        Yaz
                        1993 Audi Cab 2.3
                        1999 Audi S8 D2 FL
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          got to be 17s for brake clearance. currently got 245 40s on my rims but prob Im a little less width not sure about off set it confuses me! i have read 35 or 40 would give clearance. i would like to run the original size as audi intended but obviously 17 if poss.
                          • Yaz
                            • May 2007
                            • 445
                            Ok I think the standard offset is ET37, but maybe someone will correct me... Anyway, in the meantime i'll get some pirces over to you mate.
                            P.S. What are Rimstyle asking for these?
                            1993 Audi Cab 2.3
                            1999 Audi S8 D2 FL
                            • re2500
                              • May 2007
                              • 2185
                              FYI. I run 17x8 et 35 BBS and with 225 45 17. And with doing the slacken tighten mod I mentioned above, they just fit...
                              I would suggest u need et 32-35 and 225 45 17 tyres. You may infancy have more clearance than me if you have the newer inox kws as tr steering arms are slimmer (mine are Galv and are quite thick giving me less clearance)
                              What size are your current wheels and current offset an what width spacers are you using. I can calculate what fits on your car then....
