after a 2 week wait my wheels arrived . i ordered lenso bsx 17 7.5 with off set of 35 with 225 45 tire. anyway i got a call from rimstyle apologizing for delay but saying they had given me a better tire bed deeper dish rear wheel. went to fit them today. the tire is a cheaper one than paid for. also rear wheel is 8.5 and front 7.5 which looks silly to me. finally went to fit front wheel and back of spokes hits my calipers. if i run a 10 mm spaces it just clears. ill be having a few words Monday morning. how can they when they know the off set be such a bad fit? and why do i want 2 different width wheels?
bloody rimstyle
Tags: None
The 2 different widths is due to some people liking the look of wider rear wheels to the fronts. Mainly born from the use of wheels from a RWD car on something else, as long as each axle has the same on each side then there is no problem running different widths front to back.
To be honest if you paid for one thing and received something different its taking the piss a bit. With regards to the fitment issue I would never rely on someone elses recommendations without measuring clearances and the like myself. -
well its a lesson learned however i did research everything for some time before ordering. however changing my order without my okay is a bit off. think ill try to get them to supply front with correct off set. ill see.Comment
yes to my s2. i think the issue may be the big brake conversion. however my boleros cleared easily.Comment
Actually thinking about it more, its probably more likely the rear face design of the spokes than the offset causing the problem. Out of interest does to wider wheel have a different offset?Comment
yes the wider wheel has been machined down to a greater off set but insurers what. and yes i thought it could be down to spoke design. Im really trying to avoid spacers.Comment
i don't mind the deeper dish on rear wheel but looks silly compared to narrower front. but i am a little annoyed they supplied something i didn't order. im hoping they can offer 8.5 front to match rear but figure out the off set correctly. Will that work or cause the wheel to stick out too far?Comment
Unsure of the difference without knowing the offset, it should be stamped on the inside of the wheel. After having looked online a little I can't find any listings of offsets for the Lenso BSX anywhere!Comment
The offset on the front is stamped et35. I tried putting the rear on the front it's worse. You can clearly see the hub face of the wheel has been machined and the off set greater. I'll keep you all posted after I speak to them tomorrow.
I reckon the problems are a combo of the wheel/spoke design and the brake conversion.
All i know at the moment is that it gives me a headache
If I have read this correctly they have supplied you two 7.5J wheels as you requested but two 8.5J's for the rear ?
But your having clearance probs with the fronts that are correctly supplied
For what this cost me so far I could have bought an S2
that's it in a nut shell. i ordered 4 7.5 but got 2 7.5 and 2 8.5. and the fronts fowl the calipers. i put a 10 on space on front and it clears. still not sure about the wider rear wheel. i put the 8.5 on front with spaces and it sticks out too far.Comment
