Large front 255/35 R 18 fitted.
  • Lee
    • 1512
    Fitted some 255/35R18 up front yesterday to my Avant and they fit surprisingly well.
    Front = 255/35 R 18 on 8" rim ET32
    Rear = 235/40 R 18 on 8" rim ET35
    The tyres are Continental SportContact2 all round. According to manufacturers data the 255s complete 828 revs per mile and the 235s do 821. The difference is less than 1% so shouldn't be a problem for the centre diff.
    There is a full 3mm clearance between the steering arm and the tyre with an equivalent clearance between the rear tyre and the upright. So plenty of room! The arches are well clear too even on full lock. Will go even bigger next time but I will have to go to a wider rim.
    Took a piccy but the car is filthy. It is raining and absolutely freezing outside so I am not cleaning it today. Will take a better pic when this weather improves.
    The car is not lowered and rides on stock springs. Wound the Konis up full hard up front yesterday too and it feels fine but I haven't had a chance to go for a thrash yet (bedding the tyres in first).
    Lee
    Designun Limited....
  • Lee
    • 1512
    Reason for going wider on the front is to improve traction under braking and to make the handling more neutral (less understeer). It was pretty neutral and predicatable anyway with my other suspension changes (ARBs etc) but this should be a little further improvement
    • Chris M
      • Sep 2003
      • 1030
      Wonder how long it'll take you to wear them out mate. Maybe a weekend in Scotland?
      Cheers,
      Chris
      Cheers,
      Chris
      Silver S2 Avant : Sold
      • Lee
        • 1512
        1 trackday should do it!
          • 12431
          not sure i could get any wider tyres on mine, might be worth a try when i change them next since it isnt going to be that far away and it only takes 10 mins to change a tyre.
          I think yours has more clearance on steering arm because of the larger diameter wheel though?
          • Lee
            • 1512
            Steering arm nuckle is adjacent to the tyre sidewall at the widest point.
            I fitted these tyres to an 8" rim which helps. Minimum recomended rim width is actually 8.5" for that size but they went on fine (well 3 guys with tyre levers at my excellent and dilligent local tyre place). They look good and the tyre is actually only about 1/4" wider than the 235 so it pays to use manufacturers data to select tyres rather than calculating it as all tyres are different. These tyres are 10" wide but think I could get another inch under the arches (just) by playing with rim widths and offsets. After that it is going to be arch rolling or pukka flaring like the RS4!!
            • horvathg
              • Dec 2003
              • 556
              I'd like to see one picture in face with these wide wheels plz.
              Gabor
              96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
              • Lee
                • 1512
                From the front of the car or with the steering on full lock? Got to go to a supplier in a minute but will try and do something later on. I have so much to do before going to Scotland next week. I am leaving very early on monday morning and I haven't managed to pack anything yet!!
                • horvathg
                  • Dec 2003
                  • 556
                  As it stands straight and from som 5meters to appreciate the wideness of the tyres.
                  Gabor
                  • Crawford_S2
                    • 1555
                    Dude, i am doing my drive next spring, can you come and roll it for me with those beastie stream roller tyres:-)
                    Ragusa Coupe gone!
                    • S2 Ant
                      • 3682
                      Lee i thought cars had to have the wider tyres fitted to the rear, not the front? I thought that was an MOT Requirement?
                      Ant
                      2011 Kawasaki Z1000
                      • Crawford_S2
                        • 1555
                        AFAIK they only have to be the same size on each axle ie fronts the same and backs the same. Dont think our caring sharing MOT inspector cares apart from that.
                        Ragusa Coupe gone!
                        • Lee
                          • 1512
                          Common soloution to solve understeer on Minis used to be fatter tyres up front. I have never seen an MOT tester look at the exact size of the tyres fitted. Wider tyres on the rear is common on rear wheel drive cars to overcome traction issues.
                          • Lee
                            • 1512
                            It is pi$$ing down with rain outside. Just ran out to take this one. Should have got a bit lower but you can just see the width....just. I am not going out there again (well if I do I will take a brush and some carwash stuff becasue it is raining soooo much).
                            • Crawford_S2
                              • 1555
                              Come to think of it i used to run a mk 1 golf with 205 tyres on the front and 185 on the rear, it was awesome fun and got rid of all that nasty understeer they are prone to. Snap oversteer was interesting though
                              Ragusa Coupe gone!
