I need some help as some time or other I'm going to need to sort a spare wheel for my S2.
My car is fitted with ETA BETA Porsche Turbo wheels. Fronts are 215/40/18x8"
Rear is 225/35/18x9.5" mounted with 5x130 using a spacer (not sure how large)
What spare wheel would you guys recommend? My avus won't fit as bolt pattern is different (can't mount onto the spacer from the centre). Does the bolt patter dictate whether a rim will or will not fit? i.e 5x112 or 5x130.
Btw I have ET49 front and ET59 rear.
I've had a look at this which is a 18"x7.5 ET50
http://www.ebay.co.uk/itm/2003-Porsc...badd241&_uhb=1
Would this mount onto the spacer so long as the bolt pattern is 5x130? Would I have any problems with the rolling radius?
Sorry for the long write up
, any help will be appreciated
