You'd have to look at the disc hat dimensions.
5x114.3
Resuming,what's needed to install 114 jap wheels in our hubs?
Maybe only re drilling the wheels itself with m14 ? That's sounds the easiest?
Of course the best is doing the multi hub mod... But 4 bearings are not cheap
LWB Audi Sport Quattro projectComment
Seems that sourcing M14 to M12 studs and wobble nuts would be the easiest thing:
Originally posted by audifreakjimI might as well update this based on some experience over the last three years.
I had some 5x114.3 wheels inserted to 5x112 to start, but low and behold the inserts were not perfectly done, and a few of the studs were bending under torque. So I went back to the idea of using wobble nuts and had my hubs drilled to 5x112 with 12x1.5mm holes.
This has worked really, really well. I cut the tops off of the wobble nuts to allow studs to pass though as well. Now I can run 5x112 or 5x114.3 wheels with the same setup. My second set of wheels are strait 5x114.3.
While at the track last time, I pulled the treads out of one of the 12x1.5mm holes because I forgot to set my torque wrench.. Stupid mistake, but it forced me to get my hands on a 12x1.5mm Helicoil, actually a "permacoil" kit. It turns out the tap is 14x1.5.. So you could just insert your factory holes down to 12x1.5mm with lots of loctite, and run wobble nuts and have access to all of the wheels in the world that are 5x114.3.
I'll be watching that stud with the insert on it closely, but the wobble nuts have at least 6 or 7 track days on them and I believe they stay torqued better than normal conical wheel nuts or bolts.Comment
I'd skip the helicoils and get studs which are M14 on one side and M12 on the other. The studs, should, be loaded in tension rather than sheer and the wobble NUTS just make the surfaces all line up. In the end you are still relying on the friction between the wheel and the rotor/hub. It would be interesting to test where each configuration would fail.
In the end, if it is holding up to Jim's wide body, 275 R compound tire'd, 996TT brake'd, 20vt at the track... ...I trust it.Last edited by Mcstiff; 28 May 2013, 04:44.Comment
Just had a quote of £120 to re-drill the wheels to 5x112 M14 radius seat. Saves the need for new wheel bolts and a whole hose of other things. I think 5x112 to 5x114 is their bread and butter
Including shipping, this is quite expensive but if there's a place locally, it's a better option TBH.
The wheels I'm looking at are sold in 5x112 but the wrong offset and secondhand are non existent, so this is a good option.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
not for me thanks.
