Tyre Blowout
  • lagz33
    • Apr 2009
    • 425
    Tyre Blowout
    Now wide awake and glad to be at work and in one piece
    This happened at 70mph on the A3 along side an arctic lorry
    The bottom of the suspension strut, where the steering/control arm connects to it was clean, hence rubbing on the inside of the tyre, since I had balljoint and top mounts changed... Short of missing out the spacer, what else could have caused this to start rubbing.
  • campbellWS
    • Oct 2010
    • 446
    Thankfully you are ok! Could have been much worse ehh? Probably good it happened where it did, imagine this happened on a tight left hander on back road putting you into oncoming! Get that sorted out mate!
    • re2500
      • May 2007
      • 2185
      I know this is a very tight area on my suspension also, especially since fitting my KW's
      What i think you will find happened, is when the hub and strut were reassembled after the work. there is a small amount of slop before the two large hub-strut bolts are tightened fully, i know on one extreme of the slop travel in this area will cause tyre rubbing on the steering arm on my car. AFAIK this is really the only thing other than the offset of the wheel that can change the clearance in this area.
      Either that or those bolts came a little loose as they can if not tightened fully, and cause the rubbing.
      "Difficult is worth doing"
      • Monkeymagic
        • Mar 2012
        • 3419
        the inside of the tire runs very close to the steering arm mate. you prob have the wrong off set wheel hence the rubbing.
        • lagz33
          • Apr 2009
          • 425
          I will check if my other side is rubbing this weekend, but I bought the car 2 years ago with those wheels and its the first time i've had any rubbing issues as far as I am aware...
          Can anything be badly adjusted after having work done on it to cause this??
          Edit: The tyre that blew was 225, I know have a stock rim on which is 220 I think.
          • andyg plym
            • Nov 2006
            • 4646
            what a waste of a tyre!
            • lagz33
              • Apr 2009
              • 425
              I know right, have literally no money either so the stock rim and tyre will have to stay for a while.
              If anyone can advise on how to sort it would be much appreciated.
              Edit: Missed your post re2500, I will have to try and have a look this weekend.
              Many Thanks
              • GazzaG60
                • 4133
                id be saying wheel offset also. worth checking other side.
                you may have the issue when turning. worth checking that too.
                I ran bbs rc in 8.5x18 et 35 with 235s and had no issues on the S2.
                  With very low clearance, I imagine a badly worn or collapsed wheel bearing could cause it to. I have abut 6mm clearance on my car in this area and I do keep an eye on it. Surely it was making a racket long before it blew out though?
                  • lagz33
                    • Apr 2009
                    • 425
                    One wheel bearing was done months ago, which I cant remember
                    But no wobbling, only a slight pull to the left which I assumed was my alignment which is well overdue.
                    But no, no warning, cruising along, CLUNK then maybe 10 seconds later an almighty bang and the sound of bits of tyre flying off and ripping off chunks of my arch liner
                    • lagz33
                      • Apr 2009
                      • 425
                      Have been running with the spare since, now the other front wheel has gt a every so slight dent on the inside of the alloy (F***ING POTHOLES) losing 10psi a day so can run whilst I sort a remedy.
                      Therefore I am now done with low profile tyres, heard about these banded steel wheels, then have come to the conclusion to just buy some normal steels dont want to end up with another blow out because they are too wide!
                      Would these fit ok?
                      http://www.ebay.co.uk/itm/GENUINE-SK...item4ab37fc6ae
                      I get a bit thrown with the offset business :S am also going to get the suspension strut looked at as the tyre guy thinks it must be that....
                      Edit: The compatibility checker on the listing says it wont fit but not sure if that is accurate
                      • here2learn
                        • Feb 2012
                        • 325
                        call round a few scrap yards to see if they have any 5 stud vag cars you can check they fit before you leave and will only be around £120 ish for all four with money saved tidy up your wheels and keep for sunday best
                        • martinws
                          • Oct 2008
                          • 917
                          The clunk could well have been the hub-strut bolts moving. You are really lucky. Id guess a blow out on smaller larger tyres would be even worse with the car dropping a few inches. Probably best having low profiles here.
                            Hub to strut bolts are stretch bolts and have a defined tightening torque or 90Nm for M12 and 110Nm for M14 (IIRC) with a 90deg angle to do the stretch. I found this out at the Nuerburgring
                            Almost no garage in the world would know this, neither would they know that Audi recommend to replace the stretch bolts and that the Audi workshop manual states not to take them apart in the first place but to remove the driveshaft from the hub instead and separate at the lower ball joint... oh and then replace the retaining bolts on them too
                            So... if they just tweaked them, then they can come undone. I'll put money on the fact that they didn't even fit new nylocks though, which is just sloppy on a 20 year old car
                            • A1QSHIP
                              • Aug 2004
                              • 975
                              What brand of tire is that? It looks like a Riken Raptor. There have been reports of sidewall failure of this tire. See the following;
                              Wheels, Tires, Suspension & Brakes Forum - Tire failure...Riken Raptor - I put a set of 245/40 18 Riken Raptor's on the front of my W210 about 1500 miles ago. Today getting on the freeway.....BANG! I thought I hit some road debris and I was just hearing it bounce off the fender apron under the car. I turned off the...
                              http://mustangforums.com/forum/gt-s1...to-happen.html
                              I have replaced some of these tires that had splits in the sidewall myself. Check the other tires for splitting.
                              HTH, Chris
                              "Nulla tenaci invia est via"
