'White wheels' what paint anyone used???
Ok then I've decided to go with paint rather than powdercoating
I want a satin finish on these rather than glossy, as they will be white and I want a Motorsport look.
Alpine white would be my preference but it needs a lacquer I think, want to avoid the glossy look, and time wet sanding/polishing up topcoat.
Anyone know of a single stage white paint I could use???
Cheers Rob
It's the heat in the poder coating that either makes the wheels brittle and the crack easy or the go soft and bend,which mine did.
I had BBS rims powder coated and it didn't bother them at all, I think it all depend on how the good the wheels are and the A8 sport are Ronal so I would have thought they'd a been ok but they wasn't.Comment
They can have my car when they pry my cold dead fingers from the steering wheel.Comment
Talk to your paint shop, solid colours i.e white in this case, does not need to be in a base coat, clear coat system only. You can use a base coat clear coat system if you want and add a matting agent to the clear coat (by %) and it will take it from gloss to satin or indeed to matt.Ok then I've decided to go with paint rather than powdercoating
Cheers Rob
You can also do the same with a solid colour in 2k, which is normally gloss straight from the gun.
Metallics and mica finishes are all generally base coat, clear. i only use base coat, clear systems on solid colour cars that need a repair job as it enables you to fade out, blend the colours better.
Whilst prep is always number one on the priority list it has to be better with a base coat, clear system as i find the clear coat seams to magnify any minor errors..Comment
Well yeah that's one obvious route but as I say I don't want to spend time laquering if I can use single stage paint,anyway spoke to the paint shop this morning and alpine white L90e is single stage no topcoat required
so that'll do me!
DJ jones -thanks for info
Cheers RobComment
you missed out taking some brave pills to remove paint
