RS2 tyre pressure advise wanted
  • Jimmypatch
    • Mar 2013
    • 57
    Hi gang, I'm running Goodyear Eagle F1 225 45 17's on my RS2.
    Obviously these are not the OEM tyre sizes so what pressures are people using for normal daily driving?
    RS2 1994
    Mercedes G Wagon 1987 3.0D SWB
    VW T25 2.0 twin turbo Subaru legacy engine 300BHP
  • Lloyd
    • Apr 2006
    • 1559
    With those tyres @94Y - 34 psi seems to be about right. Maybe a bit more if you're fully loaded. (With AO48's Track day tyres, starting cold pressure is about right at 21 psi!)
    Definitely not 39 psi as per fuel cap sticker! Not a nice ride at all.
    RS2+ (now sold...)
    • Drummer87
      • Oct 2009
      • 1644
      • Home: United Kingdom Current: Scotland
      On 225 40 18 goodyears eagles I run 40 upfront and 36 on the rears. Will try 34 all round, see if improves comfort.
      • Jimmypatch
        • Mar 2013
        • 57
        I've seen people mention 36 psi all round on other threads, would be nice if someone from QST or Quattro corner would comment
        RS2 1994
        • re2500
          • May 2007
          • 2185
          You have to also remember that the OEM 245 profile RS2 tyre was a funny unique size and is comparable to a modern 225/45/17 tyre, so pressures wont be vastly different.
          Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
          "Difficult is worth doing"
          • simon20vq
            • Dec 2010
            • 1379
            I ran 38psi all round and it was perfect with the toyo's 225/45/17.
            • robo
              • Aug 2004
              • 2086
              Do you have problem with the car floating on the tyres?
              sigpic_________
              Rob
              • Golfboy666GTI
                • Sep 2008
                • 571
                • Country: New Zealand
                I run 39 (factory) in my 225/45/17. At 34 (IMO) steering isnt sharp enough.
                1980 VW Golf GTI Track Car
                1995 Audi RS2
                • Fat Audi 80
                  • 10547
                  On 245 40 17's, 34 is too soft, 38 about right and 40 s bit rock hard. IMHO..
                  The Perfectionist
                  • driftin jo
                    • Sep 2007
                    • 2222
                    You can calculate the pressure you need, or at least the minimum pressure
                    you need for a tire as it will vary from tire to tire based on load rating/index
                    and maximum load capacity of tire and weight of car.
                    For example, lets say for simplicities sake your car weighs 1600kg
                    and it is equally weighted on all four wheels, 400kg per wheel.
                    Lets take a typical 225/40/18 tire in a 94Y rating at a Max pressure of 60 psi,
                    the 94 load rating is 670kg.
                    We need to achieve 400kg load capacity from the tire so :
                    670kg / 60psi gives us 11.166kg per psi .
                    400kg required load divided by 11.166 = 35.82 psi (tire pressure required by this tire to support load).
                    There are other factors to consider as well such as weight transfer, if the car is driven hard, this will require additional pressure as there is now additional load, although this is partly accounted for by tire manufactures as temporary load increase rather than constant running load, but this will give you a starting point for any given tire as a minimum pressure you should use.
                    If you want to get really technical you can start factoring in pressure increase from temperature
                    increase due to starting pressure, ambient temperature, driving speed and style etc etc.
                    • darkhorse1210
                      • May 2010
                      • 335
                      I usually go for 39 all round in mine but it's personal choice I guess, at this pressure it's not too fogiving over potholes but certainly sharpens the steering relative to lower pressures
                      • Carl Avant
                        • Sep 2005
                        • 368
                        RS2
                        80 Sport
                        S4
                        Ariel Atom
                          • 12431
                          I normally run 36 or 37 all round for normal roads with Eagle F1's
                          • Avantus
                            • Sep 2007
                            • 941
                            • Country: Belgium
                            I also feel a big difference between 2.2bar and 2.6 bar with my assymetric 2's in 225/45/17.
                            I now always run at 2.6 bar, much better steering.
                            • Jimmypatch
                              • Mar 2013
                              • 57
                              There seems to be a lot of well informed people on here, thanks
                              What's everyone's opinion on these tyres
                              http://www.mytyres.co.uk/cgi-bin/rsh...110&sowigan=So
                              RS2 1994
